I'm soon to head off to Europe for an extended working holiday, i'm getting an Ancestry Visa, and i was thinking about a private import to bring back, as i will be there for more than a year,
The car will be for my father, and he's looking at a few things mainly the CL500 merc, newer model
I've done a search and not much returned info about importing from Europe, is this any different than say Japan?
I'll more than likely garage the car most of the time, but leave it rego'd and i'll have an international drivers license, so i might just have to take it for a spin occasionally, but will me being an aus citizen, will it classify as a personal import?
Also what other options do you think would be a good candidate?
Dad's business is in real estate http://www.reod.com.au and he already has a 2000model Range rover, and was thinking this would be the next thing to get, rangie for country properties and this for the city ones
Another option would be the new Range Rover Sport supercharged :down: alll because they are a lot lot cheaper overseas than here
Anyway, any help would be appreciated in regards to the inporting side of things and if i qualify
and also a selection of cars that would be nice or even profitable to sell again
And i'm aware that getting a new expensive merc as a grey import would be hard to sell here, cause everyone wants proven history etc of the vehicle
Thanks in advance
https://www.sau.com.au/forums/topic/221598-importing-from-europeuk/
it is no different from importing from any other country. doesn't matter if you are importing from england, or brunei or japan. any questions about the rules of personal import should be directed to DOTARS as they are the ones who will process your application not us. it won't help if we say "sure international licence is fine" and then they turn your application down. saying to them, "well beer baron told me it should be ok" won't help. trust me! talk to DOTARS, they are not the enemy.
If you are going to bother bringing something back then make it something that was never sold here. Eg anything with Cosworth in the name, a Lancia Delta Integrale, an early BMW M3 (LHD so not sure if you can rego them outside WA)
Don't bother with common or garden variety stuff.
Atom Ariel for the win!
I can't see this getting rego approval here anytime soon (been watching their website for a few years now).
You would either be unique in Oz or turn a decent profit to have the only road registerable one (that I know of anyway) in the country.
  • 3 weeks later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
