What parts should be changed when rebuilding a motor to run at the stock 7psi? I just want it to run well seeing how it has over 150k on the motor, I searched but only found engine builds that will have monster hp, I just want to get mine running smoothly and reliable before adding more expensive parts for more power
https://www.sau.com.au/forums/topic/221600-engine-rebuild/
if its just to run 7psi, and it only has 150k on it i wouldnt bother, just keep saving your money for a proper rebuild if you plan to do it.
some items you MIGHT want to replace though, gaskets, hoses, piston rings, make sure your valves are sealing and arnt carbon'd up.
how far down the track did you want to put more power into the engine? what engine?
how much money were you wanting to spend on this engine build (refresh)??
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3907562
Sorry, rb26dett, Im getting the car next week(cant wait!) and I dont want anything to happen to it in the first month of driving it. well in the future my goal is 450-500whp. mostly for weekend driving and the track for fun
well it says 150k, and could of been driven really hard, not taken care of and rolled back too
Edited by DosuGTR
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3907906
well when you get it, change plugs, fuel filter, have a look at the brakes, check all suspenion bushes. just give the car a good check over in general, if the majority of things look good then you should be fine.
dont thrash it stupidly and itl last for a while. but since ur only just getting it...you'l thrash it haha.
just see how it feels and looks before you start organising a rebuild. 26builds arnt cheap...
where are you located?
CJ
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3908588
So you want to rebuild it once to suit 7psi and basic power, and then rebuild it again later for 450-500rwhp?
You obviously don't know how much the labour/machining/necessary parts costs for a rebuild... it's BIG money.
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3909087
sorry mate but he's right. engine rebuilds are only if you need it. your gonna need your cash for everything that breaks down on them. keep a stash for when that happens
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3909333
have you had a GTR before? realize how much power they have stock? you can easily get 300awkw out of a GTR with simple cheap and easy mods like exhaust turbos and boost. if its got the 150,000 on it then maybe it already has had the pumps replaced. you would find it a lot cheaper to do a 100000km service then to rebuild the whole motor
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3909338
well in that case, maybe you are better off replacing the brakes and rotors, new suspension. while you are there, replace the bushes.
the interior would be on the way out by now as well, so order new plastics, seats and carpets.
seals around the windows are getting a bit weary, and you don't want them blowing out while you are doing a 300kmh plus pass down to the local shops, so replace them, along with basically anything else that is over 12 months old...
maybe just buy a new gtr...?
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3909624
Well I figured alot of these imported skylines were beaten on so its better safe than sorry
Dude, if the WORST happens and your motor lets go, you'll be up for a minimum $6000 rebuild (incl. labour, but mostly stock parts).
If you want to make sure that doesn't happen, you're up for a minimum $6000 rebuild (incl. labour, but mostly stock parts).
Safe = $6k, Sorry = $6k.
There is no point in doing what you're saying. You're better off changing the oil ever 1500kms like most do and hoping it doesn't spin a bearing (good luck!).
If you want to be assured your car wont break down in the first few months of ownership, don't buy a GT-R.
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3909652
Or buy one with an already rebuilt motor, or buy one with a popped stocker motor with the plan to rebuild it. No gambling this way, know what you are getting.
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3909700
yeah just go with it for now. main thing is to give it a good service (eg all new fluids - there are a lot in a gtr.....) and don't turn the boost over say 12-14psi. You should be fine, and if not you are in for that rebuild anyway :blink:
https://www.sau.com.au/forums/topic/221600-engine-rebuild/#findComment-3910330
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
