Subject: Fw: Speed cameras - Eastlink
The locations are as follows :
WELLINGTONROAD ROWVILLE OVERPASS BRIDGE BOTH DIRECTIONS 6 CAMERAS 3 IN EACH DIRECTION.
These camera's are mounted high up in the honeycomb design of the underbelly and special attention has been given that they not be seen from either direction.
GREENS ROAD DANDENONG OVERPASS BRIDGE BOTH DIRECTIONS 6 CAMERAS 3 IN EACH DIRECTION.
Conditions of installation same as above.
EASTLINK TUNNEL RINGWOOD 12 CAMERAS 6 EACH SIDE.
These cameras are located at station boxB22and can move on special slide rails that allow them to be moved forward or backwards between station BoxB22and B35. these are expected to raise the most revenue.
FRANKSTON FREEWAY TO GREENS ROADOVERPASS DISTANCE 17 STRAIGHT KMS. (IDEAL DRAG STRIP)
This area is of major concern for the State Government, at this stage no legislation has been passed for the installation of cameras in either direction until you hit the Green Rd Bridge. Signs have been erected along this 17km strip that indicate 'Speed cameras operate in this area' in both directions but nothing is operating. The Government does not want to project itself as an immediate cash cow and as a result will not introduce them until next year at this stage.
They have placed into the road when the bitumen was poured, electronic trackers which are a new system of detection that works like the ones on the Geelong Freeway that measure you by Time Vs Speed.These are still being tested and measured for accuracy and efficiency.
It is possible that random mobile units may be deployed or hand held speed guns used as it is feared that this strip has become nick named the Dandy Dragstrip by the workers.
:D
:D:):O
https://www.sau.com.au/forums/topic/221945-eastlink/
hey, are we goin to have an eastlink cruise before they turn the toll gates on?
yeah there will be, either in the vic member section or events section just keep eyes open :D can't wait to block 3-4 lanes of skylines ahead and behind in the rear-view nothing beats teh sound too.
https://www.sau.com.au/forums/topic/221945-eastlink/#findComment-3916957
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
