  • Replies 41
has this car actually run a 9 second pass yet or is he just claiming it because of the power it makes????
ive never seen or heard of this car running other then on a dyno
ohh n im not tryin to bag his car out or anything like that im just curious
Edited by UWISSH!
no...went to the track and ran 12.4 and 12.2 and then finally ran a respectable time of 10.6
Im still the only RH9 car Croydon racing has ever produced (well i built the car, and they did the engine and tuning)
Id really like to have a drive :D
it runs a hollinger seqential and ran slicks to achieve the 10.6, so even if it did run a 9 it still would not be classified RH9 as you have to run on radials.
I prefer to run the numbers before i even entertain the thought of talking up the times...but to each their own i suppose.
Edited by DiRTgarage
would like to see some specs and pic on it...
ill try and list what i know
N1 block
JUN 2.7ltr stroker crank
JUN conrods
JUN pistons
JUN oil pump
JUN 288 deg 11.35mm lift camshafts
JUN titanium retainers
JUN valve springs
JUN and ARP engine bolts (mains head and cam cap studs)
JUN radiator and header tank system
ACL race seies engine bearings
Race ported head
Nitto 1mm oversize valves
Nitto valve guides
Preformance metalcraft 9 ltr sump
TRUST 1.5mm DRAG head gasket
TRUST T88-38GK
TRUST manifold
TRUST external gate
TRUST B-pipe
TRUST 4 inch race exhaust
TRUST 160mm DRAG intercooler
OS Giken harmonic balancer
OS Giken quad plate clutch
OS Giken front and rear diffs
Hollinger sequential 6 speed gearbox
MoTeC M800 ecu
MoTeC CDI
Blitz ID-III boost controller
NOS Nitrous system (unknown quantity of gas used)
Performance metalcraft catch can system
thats just off the top of my head...ill add anything else that comes to mind.
its basically the same long engine as ours without the 2.7ltr crank (ours is STD stroke)
didnt it have twin 3040 turbs on it when it did 1000+hp at the treads???
Funny as hell, i have the same internal mods except it is a trust 2.7 kit and 280 cams in/ex with tilton triple and cusco diffs oh and 3037s twins...
havent seen the car for a while its gone in to hiding...
thought he tried to sell it, funnily enough my 34R is MNPII as well, and no i dont want to be the same... hahhaha
Edited by Dr R
yeh i didnt think that it had run the time, just goes to show that just because you have the power doesnt mean that you will run fast times
what was the story with the runs??? couldnt get the power down? bad launches? bad driver?
I also thought it had twin 3540's and an Apexi twin entry 150mm cooler.
The car definitely has all the gear to run the times very easily...it's just a matter of getting it down the track. At Compak Attak it was the driver's first attempt at racing the car and it was done (erroneously) using full slicks. A 10.6 with 145+MPH TS means that the car has the potential to run well into the 9's.
yeah...it then made 1100hp with the T88-38GK
it may have been John's first time at the track with THIS car...but he's got more runs under his belt than most (previously ran a R32 GTR into the mid 10's as well)
i see the massive brembos have been ditched, possibly to accomodate a smaller wheel for the track?
that photo is over 2 years old...Dario's ute is in the background and its been back on the road for over 18 months
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
