Pauter and mahle pistons came to......
2,027.21 + 50 international cc fee (1,758.00 usd in total)
which gives me about 10 bucks for shipping if the total was $999 rods and $750 pistons.
not bad really payments come out today so will see how long it takes to get here.
Thats a good deal for those. Well done.
For those who are interested this is ever last inch of wiring removed from an R32 GTR AFTER the bare engine essentials were stripped from the main harness.
Its heavy and the majority is usless crap that didnt work anyways.
Andrew if your interested in those bits still your welcome to come check it all out. I can make up a second billet bracket for that pump if you'd rather that over the heavy steel one. I've also got lengths of perform-o flex hose I wont be needing as well. I used it for scavengers but still have enough for another set-up.
Teaser for Duncan......
Edited by Risking
Holy f**kin shit,
thats alot of wire!! you'll make a mint with all the copper there :(
dry sump looks very good! but for now i am putting my spendings on hold for business purposes, not going to sell the car tho :) and will get the engine built in the meantime.
i like this thread! good for chatting hopefully duncan and mark dont mind!
Look at all those speedflow fittings and braided line! Hate to think what they cost :( Seriously though, have you got any more pics of the setup? It's not on the cards right now, but I'm interested in the work done. Any reason why you have to mount the pump to the engine, wouldn't it have been easier just to mount it in the engine bay? I can see keeping the lines short, but doesn't the setup mess with the power steering pump? (and air con of course). Really hard to tell from the photo, but it looks like it sits way forward, far enough to foul on the radiator, but that my just be the photo.
Feel free to use the thread for whatever jibber jabber anyone wants, just don't start attacking me for converting the road GTR to LPG. I got enough of that from my other thread!
pump is mechanical and is driven via a belt off the crank. so unless the engine is solid mounted, you have to mount it on engine. also keeps belt shorter to eliminate it being thrown off which would be bad. some pumps are also gear driven. not sure if air will factor into equation on race car.
Look at all those speedflow fittings and braided line! Hate to think what they cost :) Seriously though, have you got any more pics of the setup? It's not on the cards right now, but I'm interested in the work done. Any reason why you have to mount the pump to the engine, wouldn't it have been easier just to mount it in the engine bay? I can see keeping the lines short, but doesn't the setup mess with the power steering pump? (and air con of course). Really hard to tell from the photo, but it looks like it sits way forward, far enough to foul on the radiator, but that my just be the photo.
Mark I do have more photos of it that I can put up latter.
The sump modifications are pretty extensive and interesting to look at.
The earls lines I bought were not as expensive as one may think. I get 50% off through earls so it came down drasticly.
Yep pump needs to be mounted to the engine for movement reasons and Im using swivel seal hose ends as they also have some give in them too.
I choose the performo flex hose as its really really light compared to the usual braided line and its easier to work with.
Power steering remains as it was (just) and the air con is long long gone on this car.
The pump is a fair way forward but not as much as the photo indicates. it lines up with the mandrel which is 40mm further forward than the orignal crank pulley end.
so when u guys remove the wiring looms and start from scratch do u cut the plugs needed off the looms and solder onto new basic loom u make up or do u use new plugs?
whats needed to make it run and have basic essentials working...
front and rear lights
brake lights
indicators
battery
alternator
starter motor
attessa ecu (how many wires need to be actually used to get this working?)
standalone engine ecu
power window switches
fuel pumps
ignition barrell
aftermarket dash (stack or aem)
windscreen wipers
im removing hicas, air con, abs, dash gauges so dont need any of that stuff.
anything im missing?
Edited by unique1
Ah... makes more sense now. Was being sarcastic about the air con, but assumed the pump was electrically driven so that flow could be controlled independent of engine revs. Mechanical would of course have to be fixed where it is.
brake lights
indicators
battery
alternator
starter motor
fuel pumps
ignition barrell
windscreen wipers
Basicly yes. I have lost all the fuse boxes and majority of the relays as well.
Im using front lights and tail lights
Brake lights
alternator
starter
Attessa
haltech & data logger
pumps
dash
wipers (one speed)
And thats about it.
Use a toggle switch for ignition and loose the barrel all together ( a few theifs did that for me a while ago)
use decent switchs for everything and get rid of all the factory switches for wipers lights etc
I bought these switch clusters from ACA. there are different combinations and colours. they look trick and were reasonably priced. using them for lights and wipers and obviously ignition/start.
Brake lights
alternator
starter
Attessa
pumps
dash
wipers (one speed)
And thats about it.
If you look at the diagrams in the manual you need to use everything attessa related except the ABS stuff.
There are little things like reverse lights etc that you dont need to wire into the attessa.
Just use a small fuse block which you can mount anywhere.Yep that the ACA he'd be refering to.
Mark heres a few more photos of the sump. The tank lines are done properly now and filters all secured.
It really did hurt throwing the ross balancer up in the lathe to machine it for the mandrel but it was the way I wanted to do it.
Edited by Risking
well we did do some stuff today, but not a lot.
put the threaded fittings in with neil's toy to hold the radiator support
couple of engine bay bits - brake lines, resistor, radiator overflow, clutch slave. bonnet and stay back on for now
front hubs back on with bearings in, now it rolls again.
drilled the brake pedal but not yet fitted it or the master cylinder
thats about it I think.
Ive got an engine back in mine now. well most of an engine anyways.
Had to put it back in without a crane so two of us struggled to pick up a bottom end and get it in but it happened.
Dry sump lines all made and loom pretty much finished off besides the condute covering.
Edited by Risking
Hey Risking just a quick bit of advice about the dry sump tank location.
Not to sure about the cams regs with the tank mounted in the cabin but it may be an issue with scrutineering.
The concern i have is that it will get very fumey in the cabin breathing your dry sump tank in there as i have my tank in the boot and it still gets quite fumey in the cabin while stationary as you will be surpised just how much the tank will breath.
I will even be going to the extent of venting my boot lid and sealing off the rear bulk head as much as possible. Wont be an issue when on the track but if you are waiting in pit lane for any extended period of time it will be a issue.
I like the big tank, but I have to agree, having it in cabin would not be my first choice. Having rolled a few times (and by a few times, I mean both multiple rolls in a single incident and multiple incidents!) I would not like hot oil in the cabin with a breather on the top. Last time I ended up upside down, and I don't think my navigator would have been too happy with 130 degree oil running down his back.
Something to consider, is that there is the potential for the engine to be still running in a crash, which would have the pump still pumping oil into the cabin.
What about the spot where the ABS pump used to be, or over where the brake booster used to be?
The photo of that tank is actually a bit old now
Im aware of the breathing issue and the filters on the tank came with it and were mearly there to stop stuff getting into it. I have alloy tube with quick release clamps that extend into the boot to a separate breather tank now. The top fitting is now a sealed cap for filling only.
The tank being mounted inside the car is no issue and its already passed a pre-event inspection with the right breathers fitted.
Edited by Risking
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
