me too! 100%.
from what I understand though removing the squish zone isn't just about reducing the compression, that's more a by product, and as you pointed out can be returned by skimming the head. I think it's also about the shape of the chamber. obviously with those 2 pads removed you get larger volume but also the shap is different. I think the idea is having a smoother bowl shape gives less hot spots. in a normal head you get hot spots where there are any little angles or casting imperfections and the can cause pre-igntion or uneven combustion. by removing the squish pads you raise this threshold. the aim of course is you can run more timing and more boost which i'm told outweighs any other loss you might have (on a race engine). what convinces me further is that of the fastest GTRs I know in oz and OS, the ones kind enough to share with me what they do headwise they tell me they remove them. I should point out again for a street car the trade of probably isn't worth it (unless you have silly power) as you want be running enough boost and power to make the most of it. but doing one side is aparently a good compromise. for a race car most of these guys tell me both sides is the go. :banana: my own head? I did one side. I'll dig up some pics for you in a bit.
To remove or not to remove, that is the question? Sorry Bill.........
In a race engine I never do, because I lose too much compression that I can't get back with head/block machining because of the piston to valve clearance. I am not fan of cutting flies in pistons as that just gives even more hot spots and a thinner piston crown under the flies. You have to keep in mind the reason for squish zones, which is to concentrate and accelerate the mixture towards the spark plug, thus avoiding the potential for incomplete burn at the outer extremities of the combustion chamber. This has the by product of reducing the tendency for uncontrolled burn, more commonly called detonation. Back in the bad old days (of huge lag) decompressing an engine was considered an OK thing to do. But as we got a lot smarter in our tuning, the fuel and intercoolers got better, the need for low compression ratios disappeared. Although some dinosaurs still cling to it.
In a race quality engine, whether it is used on the street or not, I can’t see any reason to do away with the squish zones any more. Unless you use crappy fuel with a lousy tune and don’t care about lag ie; the car is used for drag racing with an auto. I still see some huge boost engines doing away with the squish zones, but that has more to do with poor efficiency in the engine which is what makes the huge boost necessary. If people spent more time on improving the efficiency and increasing the airflow instead of simply turning up the boost, then they would find it unnecessary to decompress by removing the squish zones.
Cheers
Gary
...If people spent more time on improving the efficiency and increasing the airflow instead of simply turning up the boost, then they would find it unnecessary to decompress by removing the squish zones......
well cmon then...we need ideas that fit within the budget of this project (ie $0!).
BTW the sway bar links sit a little different to standard, should I run longer bolts with lock nuts to get them closer to vertical? I think they might bind up a bit on their current angles.
Doesnt that suck andrew!!
I heard on the grape vine your doing the O/P day/nighter,,,True,???. If so can you bring my spare windscreen honey.
We could actually share my garage and cut the costs. No 15 is mine and if no-one take the other half we end up with tons of room.
Neil.
speaking of bits being dropped off, 3rd time lucky - the remote filler and roll over cut out for the fuel cell arrived today so thats another job to knock off in our spare time.
BTW we were discussing on the weekeknd......does a sway bar or "anti roll bar" actually stop or reduce the number of times a car will roll? If so that purty yellow solid one that Gary made up for us will be a must.
I bet Mark wished he had a bigger anti-roll bar on this car....
In a race quality engine, whether it is used on the street or not, I can't see any reason to do away with the squish zones any more. Unless you use crappy fuel with a lousy tune and don't care about lag ie; the car is used for drag racing with an auto. I still see some huge boost engines doing away with the squish zones, but that has more to do with poor efficiency in the engine which is what makes the huge boost necessary. If people spent more time on improving the efficiency and increasing the airflow instead of simply turning up the boost, then they would find it unnecessary to decompress by removing the squish zones.
Cheers
Gary
Thanks for the explanation Gary. I know of one engine builder who agrees with you and he was responsible for the head porting on ours, and personally, I did not want to once again remove the head before even firing it up and disassemble the head before even trying it.
Mark
I dont really know?? haha what a headache it all was tho. i need a 32gtr with a getrag in to test.. or mine will be ready in a month or so..
Looks cool though! Got a sort of croc theme going. What sort of weight savings over chromoly welded tube?
this is just under 9kg's (can handle 2000ft/lb) tho the other available model is around 6kg's (1000ft/lb)
i am wondering why i went with the larger one in the first place.... oh well i aint waiting another 7 months for one.
Neil.
I was going to but all the spots were full by the time I got my entry done. (was waiting to get the car sorted before sending it)
Greg got his in as did Steve Berry so ill probably be there anyhow.
bar thickness divided by the number of adjustment holes equals the maximum amount of roll-overs posible with the bar fitted.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
