It's kinda a rolling twelve months. We'll get there eventually. I'm now living in Melbourne so the car is down with me in the workshop. Between here and April it won't get touched as I've got to get the other car ready for Targa, but after that I'm pretty keen to get moving on it. Lot's of weekends and late nights ahead of me.
haha stable....that's exactly what i need to store all the cars :rofl:
lol michael as if you don't have 2 projects on the go yourself :P when is that race car going to be back on the track btw, was a shame not to see it at the national sprints at morgan park last month
damo, honestly can't remember. but they are a cheap forged one, originally bronze but we had Craved powercoat them white. they look excellent, hopefully they will be strong enough.....
BTW this bloody car better be seconds quicker than the production car. otherwise I'll burn the f**ker to the ground.
That is true mate. But im always doing or trying to do something crazy and overly time consuming.
Good news the race car is finally running. Needs to get tuned to suit E85 now and then its time to actually get back on the track. Stupid cars, you fix one problem, then another problem thats never been an issue pops up. Fingers crossed there are no more! The rings appear to be sealing perfectly now since I assembled this motor dry. No oil vapours out the exhaust and nothing out of the dry sump tank breather. :D Just as it should be!
Dont burn it to the ground if thats the case...just swing it my way! :) :) :)
  • 1 year later...
  • 2 months later...
hey good perserverance!
what happened is that the car was about 70% complete, when Mark had to move to melbourne for work. I had no space for the car so it moved with him, and I don't think he has got back into it.
I still think it would make a great track car, and when I need a second project again and the garage is ready, I may bring it back up here and finish it off. It really owes us bugger all and should be reasonably quick and fun.
It will never go to a $uperlap though, that event has come way too far and I'm not interested in spending $200k for 10 laps and finishing in 70th place....there are lots better places for club style competitions
  • 4 months later...
haha I'm sure it's not the only build thread on long term hold.
It is still down in melbourne gathering dust, and I would still like to finish it one day. First I have to do the ute, get the March aback, get my race card running, and then buy Brad's truck and go and recover this car from Melbourne. So, I guess not this year :)
  • 7 months later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
