Hi guys,
I just wanted to put up a post about my new Engine Monitor project. My original Engine Monitor has been out there for a while now and I have got a lot of good feedback, so I took it all on board and have designed up a new version. I'm calling it "EM Pro II". The new version now has Boost and Fuel Pressure inputs plus an additional digital channel for vehicle speed. Another request has been for a user selectable output for a water spray kit or speedo drive for cars with gearbox conversions so I have added this also. Plus the two line green LCD is gone and is replaced with a 4 line Blue LCD with white writing. Looks really cool.
The specs for the new unit are:
4 Line 20 character Blue LCD with white writing.
4 Buttons for user control.
Aluminium anodised case with laser engraving.
7 Analog Inputs:
Oil Pressure
Oil Temperature
Water Temperature
Intake Temperature
Boost Pressure
Fuel Pressure
Battery Volts
(I will allow the forced induction related inputs to be reassigned for NA cars)
Digital Inputs:
R.P.M.
Vehicle Speed
Alarm Acknowledge Button
Page Select Input
Outputs:
Warning Light
Warning Buzzer
2 Stage Shift Light
User selectable output (water spay kit, speedo pulses)
Alarms:
Individual alarms will be programmable for each input. Selecting warning light / buzzer or both.
Communications:
RS-232 Communications port for connection to a laptop or the RaceLogger to expand the channels and do data logging.
I have just ordered 20 circuit boards for the first batch. Once they arrive I will assemble and get into the software.
I will keep you posted as this project progresses.
Any comments / discussion on the project please. Its early days with the software so any good ideas I would love to build into the unit.
Paul
https://www.sau.com.au/forums/topic/222468-engine-monitor-version-2/
one piece of advice I would give is to have an option where you can set it to display the difference between boost pres and fuel pres. this makes it much easier to diagnose fuel pressure problems (failing pump, leaks, faulty reg etc) as you remove boost from the equation. it gives you a much more usefull figure to look at.
hey mate, never heard of the engine monitor (maybe im out of touch :)) but sounds like what ive been looking for.... any more details besides these features? ie is in intended to be a digital type gauge similar to the slimline stack (edit: this one http://www.stackltd.com/images/snapshot_st8900.png) which doesnt seem to be available anymore? ideas on cost etc?
have to say, if it could read my wideband 02 signal AND read real time to laptop with logging that would be incredibly useful (would be pushing my luck to log egtx6 to the same place i spose... :D
Edited by DCIEVE
unique1, those extra inputs would go into the RaceLogger I'm building. It connects to the EM Pro II to expand the channels and add data logging straight onto a USB memory key. I will put up another thread with the RaceLogger projects progress soon. I have got some testing planned over the weekend so I will report on that.
There are some pics around of the old unit, the new unit will be in the same case but look pretty different. I should have pics of the new unit in a few weeks if you can wait.
Very flash and I can't wait to get one.
I've been given another good suggestion to add support for GPS straight into the EM Pro II without the need for the RaceLogger. That way it could display laptimes / split times live on its display and store several laps in its memory.
Keep the good ideas coming guys !!
  • 3 years later...
Yes I did finished it !!
I am currently building another 10 units now. Ordered the PCB's the other day. Its like you read my mind :)
Great :)
Does it ue individual inputs or can you use a single data cable from capable ECU (like the RS232 from a VIpec V88 or CANBUS) as the input to set up all the paramters?
No offense but that would be a totally useless feature. I do not understand the necessity for a knock reading display... It is not as if you can do anything about it. A well tuned ECU using the OEM knock sensors to pull timing if necessary is all you need.
That aside, if ten more are being made I want to be on the list pending the above questions.
well you kinda can.... If your car is knocking like crazy your not gonna keep your foot burried in the gas pedal are you? With ECU's that dont make adjustments based on car feedback, I think its necessary to have a knock moniter
If I understand how the PFC works ie doesn't retard timing when high knock is sensed, then it would be good to know if you are destroying your engine if u encounter a hot day with bad fuel...
In that case it would appear to be useful to me
Edited by GTR_JOEY
Yeah knock is kind of a big thing to want to know about, my PFC hand controller has the knock level showing all the time.
Especially if a PFC is being used then a knock reading is a crucial tool for the driver to prevent engine damage.
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
