Hi everyone,
bit of a question here. I was looking to get a FMIC installed and have been shopping around. I was looking for something around the $700-800 mark. I thought the Greddy SpecM's would fit in an R34 GT-T but have been informed by a shop keeper I'll need a Spec-V. Is this the case or have some of you guys got the Spec M in there?
Cheers!
https://www.sau.com.au/forums/topic/222623-greddy-intercooler-on-r34/
Greddy spec M is out of production. and when they were in production they were very cheap as they use a cheaper core to all the other greddy coolers (still nice piping). $800 for one is pretty cheap. brand new in japan they were around the $400 mark.
I believe they have been replaced now by Greddy LS. but personally I would get something a little nicer. something higher up in the greddy range.
M-Spec fits. I Put one on mine. No cutting of fan req'd. Clearance with the bonnet is a bit of a b!tch, hits a tiny bit but no damage done. Probably the way I fitted it tbh.
Whoever is quoting you 700-800 is ripping you off. Can get them for 600 and possibly 580 or so with a bit of haggle.
Edited by Magic
Yeah i got mine for $600
Magic, you're lucky...i had to trim the fan down a little...
you're right about the clearance. bit of a bitch, but got it to fit.
pretty good fit eventually though...
Edited by ITZTRU
I'll take a pick of my install tomorrow of how to stop it from hitting the fan since I'm pulling crap out while im changing my corroded radiator hose fitting to a stainless one. Bit late in your case, but for guys doing it in the future it's a good idea. Instead of using one of the parts used to mount the fmic up. I screwed a spare onto the left side of the engine so it holds the piping in place solid as a rock. Also, need to remove the Neo engine cover. :thumbsup:
Edited by Magic
I have a Spec M installed on mine. works a treat, no complaints just yet.
Had to trim only like 2cm off the fan which isnt too much. Clears the bonnet, but a pretty big job altogether.
As Beer Baron said, the Spec M has been replaced with the new Spec LS which has a tube and fin core instead of the bar and plate which the Spec M has
Are you sure the LS is tube and fin? From the Greddy advertising I've seen they are still bar and plate, just lighter then the Spec M.
Mmmm, seems like the LS is the way to go indeed. I guess the next question that I beg to ask is, where can I shop for one of these in Victoria? I was looking around a few joints but most say they want 680 (my best quote so far).
Ideas gentlemen?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
