  • Replies 123
Posted Images
I'd kinda go lateish though... I felt like such a dodgy bastard in there cause it's so not meant for cars!! Don't think I'd like to get caught or have to explain it to someone!
I'll have that covered if we do encounter the authorities. :D
Besides if we have problems there i'm sure we can take off and find an alternative spot....Can-bra isn't that bigger place. :D
theres a million cars there every weekend getting photos. and im sure if they wanted to stop cars getting there, or down on the water front they would have by now. ive been down on the planks at night with a mate, cop car drove past and nothing. but eh, if u dont wana go down there then dont :P theres better spots to take photos anyway, and much more "dodgy" aswell. been yelled at once or twice haha good fun
Hey everybody!
It has been a while since we started talking about the banner and i am happy to see that we are trying to get something that we are all happy with.
I think that we should try and keep it as simple as possible: it is a banner, not a poster.
With this in mind, i would like to bring back Bullet's original ideas. I like the black one, but i would like to see the 'ACT' a bit smaller like in the white version; but still solid red.
Just adding my 2c and i hope this can be done for 'maques in the park', not sure when it is though
hey guys, i thought id "make" miranda draw up an idea at work.
Yes, i know its not the right size and its still a work in progess (more cars to be included) but just thought id put my 10 cents in...
worth developing?
I have more ideas, just waiting on mark to install Fireworks on my puta *hint*
My bro is an absolute gun with photoshop etc (did it as a profession for a while). I'll see if he has time to come up with something. It would probably be a little more errr arty/conceptualthan the stuff I see here (think Barney's tv ad in the Simpsons), but I'll tell him to keep it simple.
Everyone is putting in such a great effort and those making all the changes aren't complaining - Thanks, we appreciate what you're all doing here, keep bringing on the ideas :)
Ben, that would be great if your bro doesn't mind.
worth developing?
I like the idea of using parliament house in the foreground, but...
1. No one in SAU ACT has an R35 (that I'm aware of).
2. Its WAY to busy and wouldnt easily attract the eye of on lookers.
3. It doesnt actually say "Skylines Australia ACT" anywhere on it.
Just my 2 cents :D
i'll have a stab at it if ur still looking for ideas?
i did a graphic design course for 4 years, so it wont be completly horrible, just a little horrible.
warning tho, i now code 90% of the day, and my graphics work consists of mainly... uh, icons.
fail!
i'll install illustrator tonight, get some font packs, and see what i come up with.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
