Fired it up this morning.
(typical crap sound quality due to engine noise)
It's all untuned and just running on the start-up mode, hence the big lumpy idle. It wont take throttle yet, but at least it runs under it's own steam.
What ID are the toyota throttles?
42mm.
The tune on Thursday will just be a temporary measure, so that I am able to run the car at a test day on Monday to find all the problems before going to the final tune and dialing up the cams fully. Just want to be able to turn the wheels again, been a long couple of months.
I have to ask, with your choice of ECU, does the Link do a lookup comparison between MAP and TPS?
With ITB, you'll find that at different throttle positions, you get the same pressure behind the throttle body (Headed for the motor) but, you're actually getting different air, especially since you get a lot of air turbulence.
This is where you'll LOSE out on your throttle response, and get a drop in power, if it's not able to be tuned properly.
The Adaptronic which was mentioned earlier, does exactly this. The GTR doesn't have to worry about anything of the likes until you go MAP sensor on it. And then it sees the exact same issue.
Also to the person saying the Adaptronic runs unreliable drivers... I'd like to ask, SINCE WHEN?
Just a quick update. No pic's/vid's at the mo, haven't got time.
The car is up and running. Has much more torque, good throttle responce and sounds awsome!
Ran the car at two gravel hillclimbs on the weekend and found the extra torque very usable off the turns.
My mate is currently making some longer trumpets based off the info from the dyno run. This will mean we can dial in a wider power band from the cams and complete the tune. In the meantime I'm jut getting on with racing the thing again.
  • 1 month later...
I've done a few events with the ITB setup now and I have been very impressed with the results.
The car pulls much stronger in the mid-range, which is where I need it and it still rev's out easily to 8k. The throttle responce mid corner is instant and I am able to use more control when I'm looking for grip and there are no flatspots anywhere in the rev range from 3500rpm on.
The video below is of a steep hill we ran up a couple of weeks back. Compared to last year, I found it far more driveable and easier to keep momentium.
http://nz.youtube.com/watch?v=pjSTmw_WWqs
Still more tuning to be done, so hopefully with a few adjustments I'll have a wider powerband to play with.
Edited by screamin'
  • 3 weeks later...
What power did it end up making and what torque?
Do you have a dyno graph?
Sounds really nice, good to see people doing something out of the mainstream and the engine bay looks really neat.
Don't have figures for the torques or ponies, wasn't too fussed about that and at the end of the day numbers don't mean much on gravel.
It has great midrange torque for a 2ltr and this makes the car far more drivable and controlable through the corners, when compared to the same events last year.
Why would itb's be illegal, unless you guys have some emission controls or something over there, which means in that case my SS is illegal too.
After the first event the engine bay is now really dusty, so it didn't look that good for long!
  • 4 months later...
Been running it for a while now. Car is going real good, had a couple of 1st in class (1600-2000cc) and a 1st two wheel drive on one hill climb. Good to be beating the Escorts and Tereno's.
Got a couple of short vid's of last weekends rallysprint. Day started off at -5°C and didn't get much warmer!
Some photo's. Check out the frozen road!
http://www.colourandlight.co.nz/galleries/...ne09/index.html
  • 2 months later...
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
