Mark did u really leave ur credit card there or are u just teasing me :)
No I fckign did! Was in such a rush to see my cousin off at the airport I forgot to pick it up...
Are they open tomorrow???
  • Replies 461
Posted Images
Great Night out...
now here comes all the excuss's!!!
kart blew another clutch and cost us 3 laps in the pits and an extra 5 seconds on the inlap... gotta love the luck of green wang pump.
the snaggas at the end were much tastier than the humble pie dessert, well done to Mikey & Bard for their SAUWA 1st placing and also to Tomski for the unbelievable hot lap.
The guy there mentioned to me a 24 hour enduro coming up in November... maybe worth while putting together a SAUWA team?
Im in for the next 1 hour enduro though... great night and the trophy is mine next time so long as the clutch holds out!!! :)
Great Night out...
Im in for the next 1 hour enduro though... great night and the trophy is mine next time so long as the clutch holds out!!! :banana:
Hmm.. this is a bit off topic.. but now i know why was there a pimped up territory there :D sweet car mate :)
Scotty talks cheap!
You were doomed from the start... Makka was late
you lost the foot race at the start, and got owned by Team RamRod
yeah... not all of us have legs long enough to propel us down that main straight in two steps. Go-go mikey legs.
tonight was awesome, big thanks to mike and bard for organising it too abd for our kart with one of our engines that kept on cutting out
i would like everyone to know however that i won the footrace at the start :)
Who would like to do another one of these events around late November?
It was great fun. There are quite a few good drivers out there and some that need a slap for their driving etiquette...not that i would name names or anything Bart! :)
Tom, i still claim its a electronic error that gave you the 58 second lap...however, it was a fantastic lap and i acknowledge that your fast laps times were quite consistent.
To summarise the event, i would say TEAM RAMROD FTMFW!!!!!
*takes a bow*
It was great fun. There are quite a few good drivers out there and some that need a slap for their driving etiquette...not that i would name names or anything Bart! :banana:
*takes a bow*
Im in for another for sure :)
Brad im surprised you even felt that bump :D
*takes a bow*
Im definitely in :D
P.S. Someone went up my ass quite hard at the 1st or 2nd corner.. :) sorry whoever that was.. Don't know who's at wrong.. but.. i just waved my hand to say sorry
awsome night, those carts can go sideways alright :D my misses told me that when i came onto the main straight my cart was making skidskid noises, suprised we came 4th or 5th with nearly a flat 1min time, my co driver had never carted before and i dont think i did a dfull lap without tryna slide it :)
Yeah, you where a place ahead of us...
lol, my cousin kept asking me who was that bloke constantly loosing traction onto the start-finish straight...
Non other than Sam ey??? :banana:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
