Hi,
A mate of mine is having troubles with his R33.
As soon as it hits about 5500rpm it just stops accelerating and starts back firing. or if it doesnt back fire it just stops reving and stays @ 5500rpm...
We are certain that is not coil packs as we have had many coil pack issues before and this isnt the same.
The car had a Power FC, Z32 ADM and a 044.
The now has a Stock ECU, AFM and fuel pump.
Also today is the first time the car has been driven since August..
Any help appreciated!!
https://www.sau.com.au/forums/topic/223844-r33-problems/
nah if its running fine up to 5500 rpm it wont be plugs or fuel, if it was either of those it would be coughing and spluttering right through the rev range,
but will need a few questions answered before being able to tell what it is causing it, is the afm still ok, have you swapped it with that of another car?
is the car running standard boost. if it had a z32 on it was the setup outflowing the standard afm? if so take the boost back down to standard.
R33, variable timed yes, is the solenoid still operational that lets oil flow to the lifters?????
the ecu alters fuel values when the system is activated by the rpm, flooding perhaps and detonating violently?
if so unplug the O2 sensors and leave them off for the time being as the ecu would be compensating for the richness,
also unplug the ecu temp sensor, this will force the ecu to go into normal operation as if the engine had warmed up.
is the base timing correct, assuming it was running a aftermarket ecu, afm, etc was this altered at all?
https://www.sau.com.au/forums/topic/223844-r33-problems/#findComment-3943506
It seems to have lost alot of power throughout the hole power range. But hasnt lost any boost.
Also little puffs of black smoke seem to come out the rear so it couldnt be the fuel pump if its running rich??
Could it be the afm??
https://www.sau.com.au/forums/topic/223844-r33-problems/#findComment-3945482
Almost a thread a week on this these days… *sigh*
Your running increased boost on the stock ECU. Its therefore having a fit/hernia/spaz etc etc.
Back off the boost, car will return to normal as its closer to factory. RB25 ECU's don’t like much over standard boost pressue in many instances
https://www.sau.com.au/forums/topic/223844-r33-problems/#findComment-3946101
It is a constant problem at the 5500rpm mark? My car is having similar issues, but its temperamental. Some days it drives great, other days its terrible, and of course whenever I take it to the mechanic it decides to have a good day, or half-week as it were last time.
In any case, next time it plays up I'm driving it straight to him. I'll post here on what he finds.
https://www.sau.com.au/forums/topic/223844-r33-problems/#findComment-3947828
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
