My two rigs, had the cefiro for almost 7 years now, i remember back in the day when you would see another one once a month at best
and its still lookin good to this day
u might remember this shot from all those years ago, your ceff, iain's laurel when it was still RB20E, and some other shitbox :domokun:
Woa blast from the past, that was taken ~4 years ago, great photo though, brings back some great memories too cheers Matty!
Ive done over 75000km's in it now and it has been off the road for half of it haha, it needs a bit of love at the moment but i might be selling it soon i've just ran outta motivation as much as i love the car
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
