na some bloke on my fb lol
luke took this one......a bit later in the day when tyres jumped out in front of me :P
not the exhaust pointing the complete wrong way and sticky tape holding th paint on the rear quarter :laugh:
yeah pretty good dude, only things were temp issues and a split coolant line, was only a slow leak so a top up after each session got me through the day. We are pretty sure the temp issues are linked to the split hose and cooling system not being able to pressure up properly, see how it goes at G1 i guess.
pretty happy with these shots from the weekend! had to pay for the hi res copies, but worth it.
Looks very tough in this shot, nice. Much damage besides the obvious? Saw the vid, looked like fun.
This is probably my favourite front shot of my Ceffy at the moment, took it about a year ago, made it onto Speedhunters. :)http://speedhunters.com/archive/2010/08/10/readers-rides-gt-gt-your-classics-pt-2.aspx Currently getting a FMIC installed and the bonnet will be resprayed to match the rest of the car in the next couple of weeks, so it will be looking a bit different soon.
And I kinda like this recent one of the rear a couple of weeks ago, just a quick snap parked outside a friend's house.
Edited by Stang
not yet, only put em in tonight. theyre made by Qest.
if people are interested in a set, they make em for 32s and 34s as well as all 4 doors variants and also for FD RX7s and JZA80 supras and the bloke who brought mine in is organising some more sets in the very near future. they also make different styles, and you can even choose the colour of the boards too so theres about 20 different variants just for a series 3 gtr like mine!
look out for the thread about them soon
their the one i sent joo ages ago menzell. there supposed to be the shit, and judging by the photos the best LED ones out there, (apart from nismo on a 34)
im still undecided on the led indicators and reverse light/fog light though. would be keen to see a pic with them on too
Thought the name sounded familiar. They do look quite sexy
agreed. the other aftermarket variants of R33 LED tail lights look like 4 cleveland steamers on the back of a tugboat
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
