cheers DC. yeah that was from last night, Josh had his 33 out as well which was doing mid 12 also, his is much better to look at than mine though.
Was hanging out to do this, got some Nitto's off MattR not long ago but just have too much and have the Time-Attack coming up on the 11th June (pending weather) - and a little weary with the gearbox/drive-train prior hence had to make late decision to miss it :( plus it got shifted from original date which was the killer... but great time and that is a good reaction time as many have noted! Can hardly wait till the next one!
Only photo Ive got until Lukey puts some up from the drags, tell your Mrs thanks for the pic nelson.lol
Managed a best of 12.7 @ 120.1mph, 2.5 60ft. has the power, just need the traction, wasnt too keen to drop the tyre pressure too much with cheap 235s on a 9.5"rim. I know this isn an ideal drag set up, but i was keen to know what it would run how i drive it everyday on the street with no changes. I think ill attend the july 1/4 with some drag radials and stock suspension to boot.
I just looked through my timeslips and my best 60' in the S15 was 1.902 - and sadly that wasn't on my fastest run. I never ran on drag radials - I now wish I had tried some back in the day, as I always spun some through 1-2 and 2-3 gear changes. Helps that the S15 was only 1,250kg too :)
^^ Someone changes their rims....Look like Enkei light-weight :P Good to see 3 skylines in the same pic
Thanks again DC
Would be good if more imports go out, i was getting tired of the big blocks passing me on 2 wheels :( Going to get some prices on drag radials soon and pretty sure ill be out for the july street meet.
The enkeis are sweet, aggressive stance on it looks awesome.
Luke has his pics up, there are a few of yours.
  • 2 months later...
Haha harsh, I didnt know that threads in the SA section meant that others were unwelcome??
I obviously posted my other car in here a while back, and this was still in my "my content" list, with a new post, therefore I posted my recent aquirement
Go ahead and delete it if it is that much of an issue :s
Nah it's not an issue mate - I was just wondering how anyone from another state even found their way into the SA forums, that is all. And I did say your car was pimp :)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
