Yank Tries To Turn Cpv35 Into A R35 Gt-r.
AIT's been selling that front bar for yonks... just took a while for someone to make a decent looking car with it.
Its based on the GT-R Proto as well, not the production R35 GT-R
http://www.aitracing.com/shop/gtr-style-co...upe-p-1445.html
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
