hey guys got my turbo put on, all tuned on 16.5 psi running 251rwk with all supporting mods.
the turbo does hold boost but as soon as u hit 5,000rpm it just hesitates and drops off to 5 psi. can hear a hiss but cant find it.
took my car for a drive tonight and didnt feel as strong at higher rpm.
boosted it again and it got way worse. in 3rd gear soon as i hit full boost car feels like the brakes are being applied and wont rev anymore.
the first couple of times when its just warming up is fine then it does it. boost was dropping down to 4-5 psi.
turbo is new. checked all my hoses and inspected the turbo and its perfect still.
only thing i can think of what i did last week i wasnt paying attention and i ran up a rounded gutter and cracked my front bar. been doing it since then. few days ago
Edited by R33GOD
https://www.sau.com.au/forums/topic/224398-need-help-r33-gtst-related/
i have a blitz bov. its atmo
these are my mods
stock internals
hiflowed ball bearing turbo 450hp
splitfires
pfc
blitz fmic
tomei pump
600cc injectors
z32afm
stock intake pipe with k&n air panel filter
full 3in exhaust.
hid boost controller
Edited by R33GOD
have you checked all your pipework? sounds like a leak from something.... try getting under the hood and flicking the throttle cable see if you can hear where the leaks coming from.... as for the car feeling like the brakes have been applied that souds like saftey mode so you dont blow it up....
ok fixed the hose problem but it still drops off boost sometimes.
it only does it when its been thrashed after about 6 times or so.
spoke to my tuner and he thinks it could be my hdi boost controller solenoid getting way too hot. or an actuator issue?
thoughts and experiences if anyones had a ebc prob or actuator prob?
today i further inspected the problem and still couldnt find the prob.
so far i have done a boost leak test.
changed boost controllers
took off front bar inspected cooler and silicon piping
changed all boost line hoses from actuator.
only thing i can think of is maybe the intake pipe is sucking closed.
cause it only does it when u hit the throttle hard on down gear, or at top end as i change hard into 4th. and sometimes 3rd
Edited by R33GOD
it does sound like a boost leak coz at high rpm it drops but if it was it would have given way and popped off hope u work it out! Try connecting a hose straight from the wastegate to the intercooler piping and see what it does then?
ive done everything and soon as the car gets hot after a couple of runs its still doing it.
i done rev210's intake pipe mod also, so i dont know what to do.
only thing i can think of is not enough preload on the actuator. its set to half a hole at the moment.
another theory. if i have faulty plugs and when the car gets real hot would it cause less combustion thus the major boost drop?
mate i had simular prob wif my gtr first noticed it on a trip to melb hit full boost than dropped to half and it would only half boost up after that untill i restarted the car then it was normal again its happined about 3 times now but they have been on really hot days so i just thought it was the ecu in safe mode or something
I'd be doing another boost leak test - if you ran up a gutter and cracked your front bar youve proabbly done somthing to your FMIC or piping. Stick a can of baked beans in the intake and pump it up with an air compressor. make sure you go under the car to listen for leaks too.
ive taken the fmic out completely and inspected the piping and tanks. they are perfect
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
