  • Replies 347
Originally posted by RB20LagWagon
And i think mine is the fastest on this board
12.79 @ 110mph with 1.9 60 foot done at kwinanna with a few people from this board as witness.
*nods* I saw that run! what did ya call it sean, a "one clutch wonder" pretty amazing nevertheless :D
hey dudes
my time of 13.02 was done on the road with an Apexi Speed Meter. Since then I have cracked a 12.94
If you want to remove me because I dont have a time slip then thats fine (i dont know how accurate it is)
what about G-tech? only joking mate :D
I have recorded a 1/4 mile time at Heathcote but was in the wet and looking forward to going back to the track real soon - to see what my baby can do [34 GTT]. Hoping for a high 13, similar to Franks. Based on my TS of 100mph it should be possible after looking at all the times above :P
Great Thread BTW!
OK, i accept that my R33 wont go on your list 'cause its not a street car anymore( even with a 9.45 on street tyres & street registered at the time!)
But i did a 12.1 @ 115mph with 1.8 60' on the 7/7/2002, in my almost stock R34 GTR. On pulp with normal street tyres, & i do drive it regularly in the hills. I think the R34 list should be expanded to include this.
I wont be at Jamboree this Sept with the R33 'cause we are still finishing the upgrades, but should be ready for Drag Combat in Sydney.In the meantime my 'other' R33 is still getting upgrades( or downgrades in this case) to make it more streetable with a single turbo & should be running in the mid tens when its finished.
GTRs.............. gotta love em.
Munro.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
