i dont know if im the only one here, but i think Motul 4100 or 300v dont really suite street use....
the car runs like a pig when the oil is cold, and it never used to do it when i had castrol in it.......so maybe the oil is too thick???
i dont know. i do get heaps of oil pressure( sometimes it nearly reaches 8 bar).
anyone had the same experience???
Oil in no way can make the car run like a pig. :(
Its a coincidence.
Mine no matter what oil I run hits slightly over 8kg cm2 on the stock gtst guage. Well I lie, the castrol 5w30 would sit just under the 8kgcm2 line.
At full throttle it hits 6.5ish, I forget exactly but it is high.
yeah, i only get the 8bar when it is cold.
by saying its runs like a pig, it rattles at cold, sounds like not enough oil going through. but when the oil heats up, it runs perfectly.....
when i had thinner oil, it was good on both cold and hot....
PS Remember $49 for D1 at Motrex. Unbeatable!
i got d1 here in sydney from the mobil distributor, works out just over $59 a bottle, i got ripped! maybe next time ill mail order some over from motorex might work out cheaper.
59 was also the 'bulk' price, i should have paid about $65 per bottle but i got the discount by being friendly.
since i have put it in the only difference i see is the oil seems to warm up quicker (than motul 4100) the weather has warmed up a bit too so it may only be due to that and not the oil. (i think the d1 is a bit thinner?)
Hey Fellas, after hours of reading and researching i am LOST!!! On first service, I used Castrol R and wasn't anything special... then on my second service my mate who owns a spare parts shop recommended i use Nulon 10W40 Fully Synth Oil ($50/5L)... The car felt much smoother in acceleration than the Castrol... But i heard the Castrol EDGE is supposed to be much better...
http://www.nulon.com.au/products.php?productId=syn10w40
What you think about Nulon Oil? What group is it?
I'm tossing up between either:
- Castrol EDGE 0W40 ($70/5L @ Supercheap)
- Nulon 10W40 ($50/5L @ Mates shop)
- Mobil 1 0W40 ($50/5L @ Supercheap)
Car: R33 RB25DET, 70,000kms, Daily driving, ocassional run...
Please Help!!
Cheers,
Sarkis
Please Help!!
Cheers,
Sarkis
I would say, go for the Mobil 1 0w40. Best deal then the rest propose above.
Thanks Trex... seems like the way to go... Any other opinions?
What you guys think about NULON??
Cheers,
Sarkis
Got no idea about the engine oil but the engine oil additives looks dodgy. How can PTFE is used in the engine oil? Sound like a "Slick 50" type of advertising to me.
More information on PTFE in engine oil.
PTFE
So why would you choose Mobil 1 over Castrol EDGE? What are the benifits/differences?
Cheers,
Sarkis
Both M1 0w40 & Castrol 0w40 are group IV PAO base but M1 reputation is better with track/race proven and the oil is $20 cheaper. It's a no brainer... Go with M1 0w40.
ok guys, need to clear one thing up..i spoke to a mate about engine oil. he states that, as a car gets older, or as it becomes more worn and torn, the engine needs thicker oils.
now, he says 5/40- 10/40 and the rest of em are the sorts of oils you would use in brand new cars with out much wear..
i hav been putting penzoil 20 50 in my rb25 and hav had no dramas for the past few years..
now this is my question!!...why is everyone putting such thin oil into these liners, which are 5-15 yrz old now.. should u be putting thicker oils as the kms tick over?
please clarify this, or better improve my understanding. cheers :P
Generally not true, it's the condition of your engine that determine the viscosity needed, not numbers of years. In fact if you have taken care of your engine using quality synthetic, you shouldn't be seeing much engine wear.
FYI, I'm using 5w20 oil for my 130k puny honda engine and it doesn't consume a single drop of oil. The engine pull even stronger than when i first get it at 16k mileage.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
