rule 1: Trex101 advice is a MILLION times more valid than mine.
mate, if you can get some GC 0w30, go nuts! afaik, step above the Mobil 1 0w40
this too thin stuff is crap. Trex101, khunjeng, REALLY know their stuff. It's 110% fine... don't worry about what your local mechanic says >_<
Have you tried Redline Light Weight Shock Proof? If have and doesn't work then Redline D4 ATF (only ATF rated GL-4) maybe what you need to squeeze out of whatever remaining life from your GB.
Cheers but I'm not going to waste $100 on oil when a whole gearbox will cost ~$500. Just curious if its worth it to prolong its life a bit more, if it won't help I wont bother. Anyone ever done this and had any results?
So how would I know if its protecting my engine enough? I mean it will prob cost $100 or so for it concidering its 5L I assume like most oils if I see it dropping in level quickly it means its being burnt off to quick and not protecting my engine?
Im really not into a rebuild .. I trust the advice im just taking procautions to avoid a catastrophie
Thanks
Thanks
Do a used oil analysis, khunjeng knows where to get it.
Is your engine having oil consumption? If yes, find the root cause first & fix it before you try new oil.
No its not .. its fine I just wanted to make sure the advice you gave me is able to be backed by a test .. concidering its fairly expensive wouldnt want to run shit oil and have to put more in later
mate we are no here to prove anything to you. If you dont like our advice then dont take it.
If your unsure buy Mobil 1 and be done with it.
Hows GC 0w-30 sound to you .. Trex101 said to grab some .. but im skeptical as the recommended is like 15w-40!?
yes get it and get it off Harold via his web site or ebay. His prices are not much more expensive than M1 off the shelf in Repco.
mate im just asking a question.. dont answer if you dont want to .. dont give me shit for asking tho
All I asked was would your advice cause premature wear on the engine and how could I test it .. What do you expect me to trust the advice of two randoms on a forum ive never met and all I know you could be 12?! common the questions are fair enough I just want enough infomation and ways to prevent damage that I can get..
Jebuz!!
And more to the point ill be buying the oil :kiss:
Edited by DECIM8
If the box is only going to cost you $500, then you should definately go down this path. But to answer your question, yes the Light Weight Shock Proof will prolong its life. In mine it relieved the notchiness and allowed me to quick shift. Probably the best $120 I've spent on the car results wise. I didn't think it would work, but it did. This was after a gb oil change which had fresh Motul put in. Red Line is expensive, but well worth it in my case.
S/h RB20DET box is worth $500 from the wreckers.
'Some' attempt to rip us off and slug $800-$900. Always shop around. :kiss:
I've never had issues with the castrol synthetic oil in my box. I believe its what Roy uses also; unsure if he's recently jumped camp or not.
Hi,
I'm pretty clueless about things such as oils but I've read through the thread and I'm still struggling with the concept of oil viscosity ratings and which oil to use.
I've been having a look at : http://performancelub.com
And the price between royal purple and mobil 1 seems pretty close but Redline is damn expensive.
Anyway, lets use Royal purple as an example, they make:
5w20, 5w30, 10w30, 10w40, 15w40 & 20w50
Now, if I am reading correctly, the first number "5" means that the oil flows easier at cooler temperatures.
So the "10w" would take a little longer to warm up and start flowing easily?
And the "20w" would take even longer?
The upper number, "30", "40" et cetera is the temperature the oil thickens at when its hot, I can't remember how to work out the temperature but I know the larger the number the higher temp it will take to make the oil thicken is that correct?
I've been reading: http://www.autoeducation.com/autoshop101/oil-change.htm
Anyway, on my other question, I now own an R33 GTR with a fair number of mods (I'm going to find out exactly what soon) I know its aftermarket intercooler, radiator, full engine rebuild (unknown mods), and possibly aftermarket turbo's (the auction did not detail this). The car has also done 148K, Km
Would I be better off buying a Royal purple 10w30, or a 10w40? Or do I need to find out my oil temps during use?
Or would you recommend the Mobil 1 0w40 (or 10w30)?
The car will be street driven with occasional track use, but not anytime soon so for now it will be a street car :kiss:
Regards,
Gareth
The car will be street driven with occasional track use, but not anytime soon so for now it will be a street car :P
Regards,
Gareth
There is alot of factors to consider when choosing oil weight and it's quite difficult to give you any good advice by your above description.
There are 2 major considerations in choosing oil viscosity,
1) Fuel dilution (fuel blowby into oil sump effectively thin down the oil viscosity)
Thicker oil can withstand more fuel dilution then thinner oil but thicker oil also causes friction drag, slower spool, higher FC and more startup wear.
For example: If you run Penrite Sin 25 25w60 in your engine, at 10’c morning when you first crank your engine, you would have effectively run 1131cSt startup viscosity. That’s like 4.5 time thicker then Mobil 1 0w40 (248.8cSt@10’c). It’s like running greases through your engine instead of oil.
2) Engine oil temp
Higher oil temp effectively thins the oil down.
For example: Mobil 1 0w40 is 14.3cSt @ 100'c but when avg oil temp raise to 120'c, it would have thin down to 9.1cSt which mean that it is effectively a 20wt oil (you do not want to run a 20wt oil when you racing down a track, do you). So if your avg oil temp are 90’c, any 30wt oil will do as it is effectively a 40wt oil at that temperature.
The key to the correct oil viscosity depends on mostly the above 2 conditions. There is no one size fit all oil.
Oh, IMO some brand of oil are known to withstand quite abit of fuel dilution before thinning down. Redline & German Castrol is one of them. That’s why it’s highly recommended in BITOG for track or high hp muscle car usage.
Edited by Trex101
Hey got the oil prob out of the way. To get rid of the sticky lifters which i believe is cause the lifter noise upon start up im thinking of using wynns oil flush. Ive heard some conflicting stories about these products what does the skyline faithful think about them. Im sure it would help the prob but is it safe???
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
