What happened to the r31?
He had over heating issues all day and eventually ended up with a blown motor.
But he has an RB30 twin cam waiting to go in it so he didnt really care about the old RB20 giving up.
  • Replies 221
Oh awesome Vid Jon..But I dont think that is me :( That's Jay the other white GTR cause I never saw that R34 on the track..but I heard Jay mention it :)
Jay and I where both getting happy on those ripple strips up the top :)
Aww really? Ah yeah, after looking at the full resolution video again it looks like the number plate is SIG-80E or something like that.. Oops! :(
Yeah not sure if i'm a fan of the new ripple strips... :)
So that's what my car looks like from behind ;)
Sorry to hear about all the breakages. I managed to get away with only a split intercooler pipe (15 year old original) and an airy brake pedal (needs another bleed).
Great day, improved heaps and thanks to all the peeps that made it happen :)
if i can get my car ready by then i'd be keen, specially seeing as i only manged 1 session all day. details?
its just a thought at the moment considering how much the weekend cost to get the car ready plus fuel.
how'd you go getting home. hope there wasn't much damage done
Well DAMN!!!!! Why the hell did i spend all that coin on a big build. turbo's cams etc etc.
Just looking through this thread The only modification required is "hand timing" :P
(sneaks back over the border)
:D
If you can afford it, the absolute best mod is a "bum" lap timer. Made by the same group that released the "bum dyno".
I spoke to the company who sells them, and my 1:18 hand timed, should be a very accurate 1:07 on the bum lap timer :)
:P
ha ha im gald they make both products cause once you make a bum power figure you need a bum timer to give you times that match the power!
:P
Thanks for the tip Nismo. Are they a direct bolt on mate?
Jay, you drove past VZ SS and me on the Freeway on way home when we were pulled over on the side!
And I think you were MUCH quicker than your 1.13 in your sig!!!
Sorry about not stopping, didn't recognise you guys, hope all was good.
Should be much quicker now after I was shown the fastest way to go around the corners. Definately felt alot quicker :)
:P I wanted it to be me aswell ...Anymore vids Jon...You had some good lines on the track :D Well Done
did those cable ties hold up??
I like the big ripple strips I got pretty airborne up the top when I was chasing Boz ;)
I think it was on its last legs..But pretty sure the owner wanted it to die cause he has a better motor to go in it ;)
Yep! The cable ties did beautifully thank you :)
All hail the mighty cable tie!
I've got plenty more video, it takes me a bit of time to chop it all up because the original video is 1920x1080i resolution (about 190MB per minute!!), so it takes some time to compress it down to a downloadable size..
I only regret not getting some footage from outside the car, it's all in-car unfortunately. I was also lucky enough to have clear track ahead of me for a lot of the time, so it havent got that much 'chase' footage.. I'm browsing through now.. I'll see what I can find of other peoples cars
Just looking through this thread The only modification required is "hand timing" :D
I hear that mod makes you chop atleast 8 seconds off your time, with no need for improved driving skills at all!! I wonder why no-one ever bothered to bolt one up when official timing was still in play :P:)
On a topical note, some of those pics are fantastic!!
Lol Anna! :D
post 17...
where can i find details about speed off the streets?
http://www.wakefieldpark.com.au/
edit - lol Mitch, Sam and I both post at 3:17 hahaha
haha and I mine was the only direct link :)
oOOoOOOo original post said "post 17" asking for info
then 3 people @ 3: 17 answered :P
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
