hey all
iv just brought myself a hr31 for dirt cheap and its interior and body is mint condition...
its got the stock red top rb20 in it..
i got it so cheap cuz motor aint running.. the guy i brought it from said he brought it not running and has not even looked at fixing it...
is their any comon things to check??.
it has done genuine 200 thousand kays and is 100% completlly stock...
i know most basics like fuel pump and presure... all fuses. if its sparking... knkow how to trace most things..
but on the old red top is their any super comon problems that always f**k up on them??
i pick the car up tomoro night so ill get started on checking shit...
cheeers in advance :blush:
https://www.sau.com.au/forums/topic/225021-red-top-rb20-woes/
yeah the plan prob will be to dump a silver top in it.... but if the red top is still goona work i mind as welll use it....
its only goona be a daily.... i work early mornning so the heaters and the heated seats will work wonders...
im hoping i can get her to run :).
il let yas know how i go...
is it a hard wiring conversion from the red top to silver top??
giday again...
have been playing with the hr31.. has fuel presure and injectors are pulsing... has power to the coils but the coils are not firing..
i have swapped them over with my silvertop rb20 out of my cefiro and they still dont fire.. has brand new plugs in...
any one have any idea what could be causing this???
cheeeers yall
ignition module the box on the centre cam covers correct??
i just found their are two small wires that have been broken on he right side plug??
that possibly have somthing to do with it...
seriouslly fidgetty to gt my hands in their to reconect the wires tho....
okay its down to the coils.....
they have power going down the wire's to the coils... still wont fire...
my silver top coils were exactlly the same.... but still would not fire.... altho my silertop coils work fine in my rb20 cefiro....
im lost aye....
it is a nics head i forgot to mention..
if it is only a few hundred dollar fix to keep using his motor for awhile i would like to fix it.. as i said car is 100 percent factory. so to keep factory motor would be nice,,
just want it for my daily as i have my cefy to pour money into...
plugs are brand new and coils are gettin power but still wont fire...
tried other coils that work fine on my other car.
still nothing...
what could it be.. f**kn hell aye
anyone have any idea what it could be???
and how do i go about testing the ignitor module??
would silver top and nics red top ignitors be the same??
and one more thing, i hav brought this car from interstate unregistered, i have heard to get it registered in south aus i need to go threw and inspection to check engine numbers and that??
any one know the truths about that???
cheeers
Ignition module plugs between red top and silver top are different. They are not compatible unless you changed plugs. But once you changed it, kind of hard to go back. And adding another plug to interchange them is just another point of failure.
The redtop RB20 is turboed am i right? It's a very rare engine and i don't see it often as they aren't many HR31 here equiped with it. Only Saw only one at a wreckers shop. Looks in bad shape too.
Edited by teng
yep thats the one..
turbo red top..
its one hundred percent stock as a rock.
i kinda want to keep it that way...
i have dodgily fixed the four broken wires on the right side of the ignitor and have it sparking out of the coils..
but still wont run..
possilby going to tow it to a mechainc and get leak down test and see if they can find anything wrong..
Redtop's are not rare! f**k me drunk.
redtop DET-R's are rare, but thats a totally different ball-game.
NICS are not worth the money you spend on them ( I know, I used to have one!) For heavens sake, just keep the coilvalley cover and the cam covers and swap them over, no one will know.
if you want a realiability and power out of a good 20det just get a silvertop (ie R32 etc) the Redtop ECCS is good too but as mentioned the plugs and things are different, so hard to get parts for.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
