Before going into details, I should preface this by saying there is no way that I am going to be talked out of it, it's already happening.
The car is a basically stock R32 GTR which is being road driven, not tracked at all. I've got other cars to do that with.
The system is a KME Akme, from all intents one of the best on the market and quite advanced in it's management, so no longer simply a burst of LPG pumped in. http://www.kme.com.pl/EN_autogaz1.html
This system is ecu controlled with single cylinder injection, same as with the standard petrol system. No injectors as LPG is already gas, but each cylinder has a seperate feed and it piggybacks on the standard injector signal, so the car can be tuned normally plus using the LPG ECU. The website has all the info.
My plan is to remove the petrol tank to make room for the gas cylinder and then add a small petrol tank for starting (the lpg doesn't cut in until the temperature reaches around 40 d c)
According to the manufacturer the unit is good to 260kw with single injector points, 350+ with multiple injectors per cylinder. I'm starting out with 1, but will allow room for 2 if necessary.
Install is underway. I'll post some picture tomorrow.
https://www.sau.com.au/forums/topic/225078-lpg-powered-gtr/
  • Replies 117
Posted Images
Interesting thing that most people don't realise is that LPG has RON rating of 110, so in theory, a properly tuned system should have about 5-10% more power than on 98 RON petrol. I'll put it on the dyno for proper testing when done and proper tuning. The software comes with the system an no charge and the ecu plugs into a computer through a standard serial port. This will work with a Power FC as well.
I'm not putting the tank in the boot, even though the R32 has a natural spot between the wheel arches. I think the tanks look butt ugly in the boot and are one of the main detractors of the LPG system. Hopefully I'll still be able to keep a decent tank underneath, if a bit smaller than standard. Hopefully at least 50L + 10L of petrol. Will have to fill up more often, but not that bad.
https://www.sau.com.au/forums/topic/225078-lpg-powered-gtr/#findComment-3964081
It might have a higher knock rating, but it has about 30% less calorific value per cubic mm, which (I think) is why lpg cars are down on torque vs petrol cars with everything else being equal.
So *if* you can increase the boost you make some of that back.
Petrol cools ("charge cooling") LPG gas doesnt (unless it is liquid injection. Which isn't available in australia yet). With an aggressive tune running rich combats knock. (Excess petrol = excess cooling). No cooling from LPG equals worse thermal efficiency which means down on power, or knocking. If the intake air isn't cold .. even more power loss.
I thought this post was interesting:
http://gasforum.dridders.de/read.php?4,76920,76969
and these guys have done a turbo or two:
http://www.go-lpg.co.uk/Turbo.html
but from reading them it seems like injector choice (not just size but speed of reaction) and being able to flow enough fuel is critical.
disclaimer: this is just from some time searching other posts elsewhere.
https://www.sau.com.au/forums/topic/225078-lpg-powered-gtr/#findComment-3964400
INTERESTING... shall be very interesting to see how much Gas flow you actualy get. as i went the Prins route and have maxed out my injectors at about 200rwkw.
R34nur, interesting you say that. i dynoed nearly exactly the same power figures on gas, but while at the drags i would get say 25 nock on petrol but 7-12 on LPG. will be great when more people get into this sort of thing, it will make searching for problems alot easier.
regards
Edited by urtwhistle
https://www.sau.com.au/forums/topic/225078-lpg-powered-gtr/#findComment-3964881
Yeah ill be keepin an eye on this. very interesting. You'll hafta keep us all updated for a long time after the install. before and after dynos and your opinion. pros cons etc. id still like to know what its like in 6 months time.
https://www.sau.com.au/forums/topic/225078-lpg-powered-gtr/#findComment-3965471
Cerbera, kinda funny if you look at your post.
"...ive got better things to do than spend my life at petrol stations", then a BIG "Buy my GTR!" under it
A bit Ironic, kinda makes you wonder if the fuel costs are the reason for selling it.
https://www.sau.com.au/forums/topic/225078-lpg-powered-gtr/#findComment-3965682
Ok a few photos after about 4 hours of work. Doesn't look like much, but most of the hard stuff is done. Still have to solder in all the wires and plug in all the fuel lines, but it hasn't been too bad so far.
Injectors drilled and mounted.
Close up of injectors. Room for another, but would have to remove pressure bar to fit them.
Reducer fitted with mm to spare all round
Even clears the strut tower brace (just)
Gas gauge and switch, not yet mounted, but drilled.
For illustration, this is where I'm going to mount the injector rails. Will have to make a bracket as the injector loom is too flimsy.
https://www.sau.com.au/forums/topic/225078-lpg-powered-gtr/#findComment-3965720
You can't see it in any of the photos, but all the wiring has been pulled through the firewall. I've opted to mount the ECU in cabin for esthetics and water protection. The ecu fits (jams) perfectly up in the driver side kick panel directly below the loom port. I used the loom port behind the driver side front wheel so no new holes were needed.
The only problem is that I've elected to take all the sensor feeds off the standard ecu and the wires are about 30 cm too short to reach the standard ecu so will need to be extended. There's a fair amount of extra cable in the engine bay loom, so I'm going to wire up all the engine bay stuff first, then possibly pull the cables back through and remount the LPG ecu somewhere closer to the standard ecu.
https://www.sau.com.au/forums/topic/225078-lpg-powered-gtr/#findComment-3965739
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
