I have negotiated a deal with a supplier for these stroker kits at an incredible price.
how does $5500 delivered to your door sound...yes $5500 incuding air freight, customs duty, GST and local freight costs. No surprises through customs etc. as all goods will be declared for what they are.
Included in the kit is... HKS RB26DETT 2.8L Step 1 Bore Up Stroker Kit will include the following:
HKS Piston Kit [Nickel Plated]
HKS Fully Forged and Balanced Crankshaft
HKS H-Cross Section Connecting Rods
*Bore will be increased from 86mm to 87mm
*Stroke will be increased from 73.7mm to 77.7mm
According to HKS, after installing the HKS RB26DETT 2.8L Step 1 Bore Up Stroker Kit, compression ratios will look like the following depending on which size head gasket is used:
*1.2mm - 8.7
*1.6mm - 8.4
*2.0mm - 8.1
need to sell 5 to get the price though...im in..who else?
1/ DiRTgarage
2/
3/
4/
5/
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/225501-hks-28ltr-rb26-stroker-kit/
mmmm.. extremely tempted :P
Not sure if I can scrape the money together in time... When is this group buy scheduled?
your's going to be TWO-08L? twootle? lol
Edited by Tomek
As long as they have the stock we can get them at this price.
I don't suppose there's a step 2 option on this GB is there Paul???
You could send me broke :D
To be honest i think the step 2 is not needed...but id get the step i kit balanced (thats what im doing) just to check its spot on.
Mark and i use STD Nissan cranks in our drag cars and they are up to the task...cannot see why a forged HKS step 1 would be inferior to these and would not perform.
  • 1 month later...
  • 4 weeks later...
Guest
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
