How does the key + immobiliser work? buttons on the key are just keyless entry and not for activating/deactivating immobiliser right?
If that's the case can you just cut a new key and use it? I need a spare key too but don't really care if its got the buttons or not.
https://www.sau.com.au/forums/topic/225766-spare-keys/#findComment-3977125
key has a transponder chip in side of it. this chip needs to be coded to the car for it to start. the buttons are for convienence.
https://www.sau.com.au/forums/topic/225766-spare-keys/#findComment-3977172
nissan. prepare sof a shock though. these cars run NATS 5 so whoever does it will need that protocol and the immobiliser code before they start.
Chris,how good is NATS 5 ? From a theifs perspective?
Is it the fith gen of a security software pak or just a fancy name?
Also does the key remote have a rechargable battery inside or is it a standard button cell?
https://www.sau.com.au/forums/topic/225766-spare-keys/#findComment-3977264
I believe AJ007 is enquiring about the intelligent key as he has PM'd me a couple of times regarding this.
Chris: his is similar to mine, with the keyless ignition but he did not get the intelligent key fobs with the car..I guess only way around it is buy one from yahoo and get it programmed?
https://www.sau.com.au/forums/topic/225766-spare-keys/#findComment-3977359
5th gen nissan antitheft. it NOT an alarm at all. it will simply disable the fuel side of things via the computer.
if you swap the computer it's gone anyway.
as for the remotes - button cell is what I have seen in most of the ones I have worked on. the one I have here currently has a dead key. remote works but the transponder doesn't - result - car cranks but wont go.
jon,
he's asked me too. doesnt have the NATS codes though so he's out of luck. told him how to ATTEMPT to get them. if he's successful then the key should be able to be done locally.
if you get time I'll run a tool over yours to see if I can do it.
https://www.sau.com.au/forums/topic/225766-spare-keys/#findComment-3977858
just wanted th throw this in the mix..
i was a metro nissan today in the spare parts/service department and a guy came in wanting to pick up his car. he had a loaner car - a nissan murano.
he pulled out the key he had for his murano to reveal the same key as we have!
something worth investigating if you need a key
https://www.sau.com.au/forums/topic/225766-spare-keys/#findComment-3986410
looks like x-trail is a closer cousin. I found out the std non-brembo V35 brake pads are x-trail items. I won't be surprised if more parts are even closely related.
but still the issue is will a local dealer do the immobiliser reprogramming on a V35 if it's not a Murano or X-Trail?
https://www.sau.com.au/forums/topic/225766-spare-keys/#findComment-3993665
no.
did you get the keycodes with the car?? without that nissan can program the key to the car and get the remote entry working but will not be able to program the immobiliser side of the key. now without that the car will spin over but not start. the NATS system cuts the fuel via software. IE no immobliser keycodes = no immobiliser data to the ECU = no fuel.
does that make more sense.
the code will be on a steel tag attached to the key if you have it. (write it down if you do!!)
https://www.sau.com.au/forums/topic/225766-spare-keys/#findComment-3994083
no.
hi chris,
Im pretty sure itll have the code attached, if I have the code, then
I can buy the x trail key
and get nissan to progn it
and i should be sweet?
thanks for your help!
https://www.sau.com.au/forums/topic/225766-spare-keys/#findComment-3994140
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
