  • Replies 42
i was thinking of a getz myself.
i used to work at hyundai, they are a good car in general.
just keep your eye on your rear wheel cylenders as they tend to leak.
also some were prone to have a knock from the rear brake. they are very tempremental with handbrake adjustment.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3985965
Barina is also $14990 drive away these days.
well if you're looking into things as gheyz as getz etc, might as well go the whole handbag.
Its not for me...Im saving up for a current shape corolla ascent :)
Barina is a Holden... I am sceptical as how long it will be till the crap starts falling off. Actually I dont want another Ford or Holden, period.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3986251
Brand new ST Tiida is $19990 for Auto
2006 models are as cheap as $14K
Bought my wife an ST-L model brand new with 5 years warranty and on road etc for $22K - Auto
Not too shabby at all... I like the look of this one
http://www.carsales.com.au/used-cars/deale...de&__Nne=20
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3986268
The Getz is POS.
We have one as an emergency car, i drive it when i cant afford petrol for my r32 :laugh:
Full of cheap plastic, vibrates on idle, loves to understeer, automatic isnt responsive. It jumps to a lower gear for no reason and makes a lot of noise but still doesnt move anywhere.
Isnt even fuel efficient, manual says like 6lts/100km. Ours averages like 8~
Ours is the first model to come out, so it could be much better in the newer models.
However it does save me petrol money :D
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3987359
If you buy a manual 1.5L they are good. They did win Australias best small car 2 years in a row. I mean we all know its a little dodgy that awards system, but they have all the kit, engine, ac, abs, airbags etc. Good for a run about. But really its not worth it if your keeping the skyline. $15k is a lot of petrol.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3987379
Getz is crap.. Honestly dont buy it .. Its cheap, seats are crap, and it seems to fall apart.
I do have an Accent which is very good, its a 97 and goes hard for a 1.6 litre it spins first and second so pretty ballsy. Olds have a Elantra too $20,000 new which is cheap as chips for a new car with electric everything and onroads + insurance. Its very comfortable.
Id prob go for the accent for a good reliable car. cheap to run, I fly around with it on empty for a good 3 days.. fill up when the light turns on.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3987401
I passed my driving test in a Getz (driving instructor's car, since my old VN probably won't pass the safety check.)
As a car to get from point A to B & back to A, it does the job, anything else... don't expect much.
& being a hatch & small its easy to park, about the only things I can think off.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3987430
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
