Hi,
Im just about to install an ATI harmonic balancer on my RB26, and i was flicking through my engine (workshop) manual and discovered that there were two vastly different torque recommendations for the 30mm crank bolt.
There is an exploded view diagram of the RB26, and it has 446 - 544Nm (45.5 - 55.5Kg-m) with an arrow pointing to the crank bolt. However, when you read through the step by step instructions, it says "Tightening torque: 142 - 152Nm (14.5 - 15.5Kg-m)" in relation to the crank bolt.
My manual also has the instructions for the RB20 and RB25, and the recommended tightening torques are all 142 - 152Nm.
I cant see why the torque for the Rb26 should be any different, let alone almost 3.5 times that of the other engines. Its a massive amount of torque; that means you've gotta apply about 27Kg of load on the end of a torque wrench with a two meter handle!
Im wondering if its a typo in the manual, and the correct torque is the lesser of the two. If anyone could shed some light on this it would be appreciated; especially those who have had experience in installing these balancers on RB engines. Its a pretty important topic i reckon, as its an engine destroying problem if anything fails down there.
I wish i could supply some pics, but if anyone else has a manual could you verify this for all of us. I got my manual off a forum member who sold me a disk; i cant see why i wouldnt have originated from a Nissan maunual.
Thanks,
Shaun.
Edited by Shaun
https://www.sau.com.au/forums/topic/226987-correct-torque-for-rb26-crank-bolt/
Yeah, thats the same diagram as mine. You'll notice that in subsequent pages it recommends the 142-152Nm. It would be good to clear this up, as im a bit nervous about putting that much torque on the bolt.
Ive heard that you've gotta put the car in 5th and have someone with their foot hard on the brake, then use a stupid long handle to get the 500Nm. Apparently it sounds like the gearbox is going to let go under the load!
We need some engine builders to shed some light.
Shaun.
Edited by Shaun
Permanent Threadlocker + big breaker bar and hang off it is how I've always done it.
I drop mine in fourth gear with the hand brake on; never had issues with it moving.
I've always figured 4th would be the strongest gear 1:1; Don't like the idea of forcing 5th even though I'm probably only able to get 200-250nm in to it and no doubt the motor makes more at peak torque.
the last time i took the bolt out of my rb26 when i did the timing belt, it was on so fkn tight... ridicuous..
i put it back on and tightened to 156nm.... and then when the turbo popped and killed the motor... i STILL couldnt undo the bastard! lol
its like it tightened itself!
Why no threadlocker?
Doing mine up to basically as tight as I can. 200nm or so with thread locker its fairly easy to remove with a normal breaker bar.
Onyl reason I've used threadlocker is every crank bolt I've pulled has had some on it. Be it from factory I'm unsure; Multiple RB30e, 2 x rb20det's. Given the age I'd say they have all been apart prior.
im an engine builder and mechanic by trade
500nm+ is very wrong...
u would snap the bolt or the destroy the thread.. 142-152nm sounds about right and i wouldnt use threadlocker either
Im with you mate. Over 500Nm just sounds too much. I dont think my 350Kw engine even makes 500Nm of torque. Imagine if you snapped or stripped the bolt inside the crank! What a fcuking nightmare!
As for undoing it, ive heard that you can use a 300mm breaker bar and rest the handle on the radiator support, then crank the car (with injectors disconnected or something like that), so that the engine turns but the bolt doesnt. Do you think thats dodgy?
Anyone else with opinions or experience?
Shaun.
I would invest in a decent impact gun and compressor guys. You will end up using it for lots of other jobs so its worth it
That way you can even have the car in neutral and crack a bastard tight crank pulley bolt without the engine turning one bit. When it comes to tightening just a few seconds with the gun and its all done. Should always double check it with a breaker to be sure however.
I was thinking of doing it this way for my build. what PSI would you set on compressor? also would you use a torque wrench to test the bolt afterwards?
threadlocker?
cheers
rob
  • Like 1
there will not be many regular impact wrenches that can deliver 500Nm. some people use a special gun with a reduction gear to get the required torque. as for whether or not it's correct, I'm not 100%, but lots of people that I know, who are 'in the know' tell me it is. I do also know I've seen a fair few RB26 balancer bolts come loose, no doubt they were not tightened 'enough'. mine has been one of them. :P
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
