My friend had one on his car and I wouldn't have called it silent that's for sure. You could hear him coming from a mile away.
On the road both his and my R33's performed very similar with nearly identical mods. The difference was I had a HKS Super Dragger. Mine was much quieter especially low and the performance up top appeared to be basically same.
So, the HKS Hi-power Silent was a good exhaust and sounded pretty good too. In the end it just created too much attention and wasn't as nice to live with every day so he sold it. He felt like every second person was going to call the EPA.
I run HKS Silent Hi-Power exhaust on my R34. LOVE IT.
It's quiet enough for a very free flowing exhaust. I think I sit on the dB limit at idle. Obviously it's a little louder when you're on throttle but I am running some mods that don't help that situation.
Cheers.
I am running one on my R33 full 3inch system and high flow cat with about 340hp atw.
As said already they are not silent by any means. They give off a very nice RB tone.
I don't think there would be any power loss unless you go a size that's too big for your set-up.
So any upgraded exhaust system will usually be much better performance than a stock set-up exhaust.
So basically if your after a nice tone and have the money to spend on one then they are a nice exhaust, But if your already running aftermarket exhaust and you are happy with the tone you already have then i wouldn't bother spending for a small gain if any. You could spend money on a better flowing high flow cat which would probably give you a better gain.
Hope my 2 cents helps you out.
Cheers
Nothing wrong with the HKS Hi Power Silent...as said...they still flow well...just that they have spent time to engineer a proper exhaust that keeps the noise down...
I went from a loud as custom exhaust with a cannon muffler to a quiet trust system and picked up a few kw actually...quiet doesn't necessarily mean restrictive...
As everyone has mentioned above. Hard to question HKS's workmanship. You will without a doubt notice incredible gains coming on boost when added to a hi flow cat and front/dump pipe.
Don't get the HKS Silent Hi Power confused with a aftermarket exhaust that has a removable silencer. Those are what cause restrictions. If you pick up a HKS silent you won't find a silencer shoved in there.
m2c
Cheers.
Jeeeesus. If you sit on the Db limit at idle, thats pretty loud. The Db limit is supposed to be at 75% of peak power rpm; so 5500 rpm or something like that.
Shaun.
I got one on my 32 gtr.
I personally think its too quiet for me... it does have a nice idle tone to it.
I dont think cops will ever pull me over for the noise tho.
My hks hipower silent catback also has the hks front pipe with stock dumps..
I only noticed a big difference when i changed my catalytic converter (since my old random jap catback had rusted) to a 3.5inch hi flow one....
Gotta hate compliance cats :(.
I have an HKS silent series exhaust and I like it. I don't know what my "gains" are, but it is a very nice system for my car as it is a DD and I don't want to be obnoxious. My car came with it from Japan, but I also got a down pipe and a test pipe when I got it here and that made a difference in sound (little louder and deeper) and turbo also spools a bit quicker.
The only reason they named it silent is because they have added a small hotdog resonator in the pipe as opposed to the standard hks system which has none. So really it's not in reference to it being so quiet no one can hear you it's just they have added this little piss ant thing in to make it a little more street friendly than a straight through pipe. In terms of power gains, unless you will be running a big hp car I doubt you'll run into exhaust restriction problems.
Hi there,
Yep bought a hks hi power silent for my gtst running the 2835 pro s turbo kit. Way too loud - drove it round the block and took it off - sold and bought a trust PE 2 (Power Extreme 2) - it's much quieter and the car makes about 260 - 270rwkw.
The hi power silent sounded like a race exhaust in comparison and you'll get too much attention from traffic police - don't forget though that stock turbos bring the noise down in comparison to larger ones.
Hi there,
^^^^Yeah, thats important to remember.
There is no point in comparing a car with a single highmount to a car with smaller twins (or single), as the turbine housing size makes a massive difference to sound. I remember when i changed from a 0.82 ar to a 1.06 ar and, with everything left the same, the exhaust note from the 1.06 was significantly louder.
Shaun
Shaun.
True but with my setup, there's not much I can do to bring the noise down under load. I just have to deal with it. Unless I start shoving in silencers and no one wants that! To be honest, I don't think it's quite at 92dB at idle but it would be close.
Cheers.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
