Id just go with what some of the guys who have built some fairly serious GTRs have reccomended i.e. Duncan said JJRs
I personally wouldnt put part on my car that i havnt had someone reccomend, and I have never heard of GKTECH, doesnt mean they are crap though
They look ok, auzzie company, and they use them on their own engine.
Could be worth looking into what material they are made from, it doesnt say on their site.
Good price though, might be worth a try...
Yeah..
I was heaps hesitant when buying mine, did the research, asked the right people and seen them on plenty of quality cars..
So picked up a set of JJR items, good bang for buck.
In a lot of cases it's not the cam gears its the mechanic!
look an adjustable cam gear is a very simple thing - thats why cheap copies work OK.
the important thing is that the centre locks the outer ring firmly in place. pretty easy even for the chinese factories to get right.
the other factor is....how accurate is their base setting (ie 0 degrees adjustment). When people say 4o retarted on exhaust and 2o advanced on inlet as a starting point, it assumes your new cam gears are 100% the same base angle as the factory gears. If they are only 1-2o out you get a totally different result (and it is literally mm only in difference between perfect base and way wrong.)
But the thing is, as long as you can spend a bit of time on the dyno, you can work out the best for your engine, cams and gears, regardless of whether their base setting is 100% right or not. so just buy the cheap stuff, start at a good base adjustmennt, and get you tuner to spend some time checking different settings.
And if you are wondering if adjustable cam gears are worth the trouble, even on a pretty stock motor - this is my most recent experience:
totally standard motor, standard cams, r32 n1 turbos, standard intake, standard boost (0.8 bar). adding adjustable cam gears made 31rwkw difference (over 10%).
I can understand both arguments, the "cheaper" ones should do the ob just as well in theory, but I think in the end you get what you pay for, I think I will settle for the JJR ones as its an important piece of hard wear and $100 - $150 is not much in the scheme of things and will have piece of mind they will not jam and the timing is on.
I think I might try the JJR cam gears, prefer to use something trusted by you guys. Just Jap has them for $250 for a set. is this around the money (locally)?
Also i'm taking my car in get to get a PowerFc installed along with a few other bits and pieces, would installing these add a lot to the bill?
Those actually look quite good, if you get some then let me know, cheap as well, but are they any better than others??? Ive got to make the decision soon as I am doing the 100k service and these at the same time.
Big jimmystyle, if you are installing these then you have to remove the cam gear cover, the timimg belt, cam gears which is not an easy feat as there are a few steps to get everything off, I dont know what the bill will be but it wont be cheap.
Edited by cefiro
Installation is easy, I could knock it over in an hour or so. I did it not to long ago in my R32 GTST and it was pretty straight foward
Its just picking the cam gears that's the hard part :P
Last time I used HKS cam gears and they set me back around $300~ but I don't want to be spending that much again, $200 and under is what the aim is as they all basically do the same thing
$129 for a pair is a killer price but are they too cheap to be good?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
