Will there be a meet up/cruise to the accomodation from Syd before hand?..
That way its a little more interesting of a drive up to ACT?..
And.. confirmed..
Im in.. Will pay in full on Thursday when I get payed :(
  • Replies 329
yeah i was thinking about how to get down there aswell, i know the way so if people wanna drive down with me thats fine, i think a week before we should post up a new thread with different meet up times and or set off destination for some of the people who might get lost or want to drive together, i think the drive down will be just as good or better than a usual sau cruise
+1
Because I sure as hell dont want to drive 3 hours by my lonesome self!
Will i need a sump baffle kit for this event? I fear oil surge.
Nah, it's easier on your car then a track day. A short stint around the back track and a bit of fun on the skidpan isn't much to worry about :)
It is recommended that you over fill your oil though, just for safety :thumbsup:
Doof means just over the humps for the GTR's.. :)
Gulp... na no worries, I will probably be looking over your all car though to see what things mines missing, ie various interior bits etc.
As has been shown before though, texi isn't about the car really, it's about the driver, hell I got beaten by a starlet as did most people in the first one lol.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
