Out of interest:
If you took 4 photos of a car from
i) the front
ii) the side
iii) obliquely from the front
iv) obliquely from the back,
What's the greatest car design you've seen of a car from the 70s (in stock form)???
(Was it the Miura; or perhaps the Alfetta GTV; or perhaps the Esprit Turbo, a particular Ferrari etc)
https://www.sau.com.au/forums/topic/227615-the-best-car-design-of-the-70s/
  • Replies 48
Bit of a failure this thread eh?
ACTUALLY THOUGH, >2 cars mentioned in the 80s section already were designed in the 70s !!!
Due credit goes to Lamborghini Countache which I saw at the SantAgata Lambo Museum 2 years ago. This place is a must see if you're in northern Italy. Much more friendly than the Ferrari Museum ' cause they actually allow you to see the factory floor.
Due credit goes to Lotus Esprit T. which is also a 70s design but with hardened corners to it. Seen Roger Moore in a white one?
Cheers, T
Was it the Miura; or perhaps the Alfetta GTV..
Did you mean the Alfa Romeo (105) 1750-2000 GTV? the bertone bodied cars were gorgeous, or are you thinking of the wedge shaped Alfa Romeo gtv6? it was ok but not in the same class.
The Miura and 2000gtv are two of my all time favourites..but both of those cars are 60's design.
A 60's thread perhap?...lots of sexy steel from the 60's.
Edited by madbung
Thanks for correcting me on the Miura which could be definitely conceptualised in the late 60s with the film Italian Job
The Alfetta GT is not as valuable as the 105 that you like so much. But somehow I like that 1974 shape that came out then and became the Alfetta GTV in late 70s as a 2 litre fast cornering bullet. The GTV 6 came out around '84 and won many races in Europe as well as here. It was made famous in Octopussy when 007 stole one and drove it like he...... well you know the rest.
My favourite design? The Alfa Romeo Montreal !
Oh yes...the Montreal is a honey and good buying atm.
Miura first rolled out in 66 and is still about the sexiest thing I can imagine on wheels, sadly it's way beyond my realm. Probably a $1mil + price tag by now.
Meh the Lambo hasn't aged well has it? give me a De Tomaso Pantera over a Countache any day...you don't have to be a midget to fit inside, you can repair-service it in your driveway and even better still it goes around corners.
They don't call them the "panty-tearer" for nothing :D
Edited by madbung
Sorry mate but i would take the Lambo any day of the week over the De tomaso... Lamborghini Countach would have to be the sexiest car ever built.... As for local cars i think the Falcon Coupes were the best looking things available... A9X Torana not far behind
I wouldn't know, I don't move in those circles...please tell me what the gossip is.
Can't imagine any Marys monstering one of those around the track, but hey if thats what you know..
Who am I to argue :bunny:
If that is a gay mans cars, grease me up and call me Nancy i'm ready to turn.
oops
Edited by madbung
does late 60's count? ie 67-69 SS camaro?
Why Not?? It was a real mean looking car with its open mouth; cool stripes across the bonnet and down the sides of the front quarter panel/
Engine? The big one had a 427cu.in. did it not. Correct me if you will
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
