  • Replies 244
ill give him full credit once its tuned and running properly... its only idling and light revs atm lol
dont let it idle for too long...id keep it shut down now until you can give it some decent revs with the engine loaded up as this will help the rings to bed properly. Then feed it some boost!!
http://www.mototuneusa.com/break_in_secrets.htm
I know its hard to have it sit there and not drive it, but you should only turn key when you are ready to drive/tune it. It will give the engine the best possible chance to bed everything in.
that link is how i like to do things...don't baby them...run them hard to give them every possible chance.
  • 2 months later...
hows the update going with this?
any final power figures?
don't quote me but i think it was making boost at 3000rpm and full boost at 4100rpm...they got to 530hp before the dyno shat itself. Ill get Simon to post when proper info comes to hand.
  • 4 weeks later...
first proper dyno sheet 22p 536.3hp at only 7500 start to die off im gonna put it down to the size of the ex housing .81 single entry
he still hasnt touched the cam gear still set at 0 both sides and he said he still hasnt started looking for power. still conservative nearly 550ks to a tank so im pretty happy with it....
response for the size turbo it is is quite insane aswell neways have a gander
yeh ur rite file size is huge lol.... and no its not a run in tune.... thats basically a half done proper tune i had sum minor boost leaks to fix b4 he would push it ne further...... and wen i got back afta tightening a few t bolt clamps etc the dyno had magically arsed itself.... i waited 4 days in total to get the car redone only to try a sidestep of the clutch in 3rd and lets just say we found the weak point.... believe this or not but a hks gd max twin plate slipped b4 the gbox let go..... so yeh i wasted those four days down in brisbane for nuthin. im abit down for cash atm so thats the tune its gettin for the moment until the clutch is done. still tho 402rwkw is still nuthin to snuff ya nose at....
400rwkw is a good number dont get me wrong, but its only 46hp more than my 25 at basically the same boost level with a GT30. Granted im running E85.
I would have though an RB28 with big cams and a T04Z would be making a little more than that, maybe im wrong.
like i said theres still not finished.... havent touched cam gears at all 20p still 5 pound to go and also havent started pushing the timing at all yet its still very conservative. and yes e85 is good shit so ive heard im only on bp ultimate because thats all i can get..... and yeh i wasnt exactly happy with the first figure either but hey its a start and im going from there
Edited by skylinekid
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
