tarmac rallying should only be scary if the crew want to push harder than their event prep and talent allow... if you run your own race and don't be ambitious it’s no more dangerous than super sprinting or hillclimbing without a roll cage in my oppion.
fair comment
I definitely think it has the potential to be more rewarding but it still scares me... if only because I haven't experienced it... I guess if your new to the sport avoiding taking the 'racing line' and just driving as quickly as you feel comfortable in the centre of the road there would be plenty of margin for error... with some of the terrible driving I see on country/coastal roads I sometimes think everyday driving is more dangerous than motorsport!
there is a school of thought that blind rallies are safer as people have to "drive it as they see it" rather than trying to fully commit to corners based on their pace notes. Most of the QRC rounds are blind rallies. Or they were when I used to compete.
Hey a quick one especially for Stu I guess - I just heard on he grape vine that in 2009 all Tarmac Road Rally competitors will have to wear some form of head and neck device.
Any truth to that one?
yeah snowy hans remains highly recommended and always a good idea, but its still a 2.5k spend for a decent setup so still a little steep for most and only arc was being forced to upgrade for 09 i thought.
*sigh* - seems I need to find myself a new Nav for Targa Tas already.
It turns out James' first born's due date has moved from the begining of March to April 15th. Don't ask me how he got that one so wrong. But needless to say he's going to be unavailable now.
Get onto Timmy mate....... he sux, so he's probably available :D
Yep dead right benny, i make cars roll and stuff... but im interested Snowy
Thanks boys. But I think I have found a replacement should James decide its a no-go, but I will try and get everything sorted out in the next few days.
Appreciate the offer though Tim and should further complications arrise I'll be in contact.
But you'll be pleased to know Tim that my Nav just completed his first rally in the right manner.
No worries Andrew,
On that note if anyone needs a Nav for Targa, let me know. I'd love to do it again, probably in a better position to do it now than I was this year.
Preferably in something quick/Modern... say a 34 N1 :P but im not fussy at all :(
Plus my sister is in management at the Federal group so I get a good rate at all their hotels/resorts.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
