I am seriously looking mate, in conjunction with a close friend. The car is good, it's me with the mental barrier.
Also, as I'm not at all familiar with the things, my big concern is running it against the known contenders, only to have a protest lodged for something that I wasn't aware wasn't factory or legal.
At least with a Datto I really have no one to blame except myself.
What's the deal with importing race/rally reg cars from Europe? Assuming the 12 month ownership rule doesn't apply, but is it very difficult and are you able to get rally reg on them here?
Lets talk FWD... Lol! I reckon Snowman should get back to the idea of a Scirocco or Gti-R Golf or something.
They are also on my (ever growing) short list! Well the Golf R and the Scirocco R are anyways.
The list as it currently stands is
Rebuild another GTR
NSX-R
RX7
Louts Esprit (thats the Brisby coming out in me).
Or go something newer like the TT-RS or the VW option. The new car thing might appeal if I can also make it an Enduro car for Bathurst 12hr.
The only thing I do know is doing something with the 35 doesn't appeal. And neither does an EMO.
I have a frustrating hunk of engine-less metal and a Porka hankering! :cool:
Ben: Have you known anyone who's done it before?
I don't know the exact details Dane, but people do it all the time. Quinns GTR's spring to mind, both imports from NZ.
Just on the TT-RS, what an impressive piece of kit they are. A friend of mine is wanting to move on from hid genuine 996 Turbo S, and I think I'll recommend one of these new Audis. Very impressive and sound mint. :(
Given that this year both Matt and Maher's cars were showroom + a flash tune I'm sure there is a lot more to be seen from these cars in the future.
I did say to Matt at Lake Mountain that they would become the new EVO once people saw what he did in his! But I rate them highly. 1300kgs FTW!
Thats where you are wrong! :( I so wish i could have afforded to lose the 10,000pound bond on the R400 last year. Would have been great to have a real go and use full revs at Spa in the lesser R400. They are so much fun to drive.
Tricky pedals, gearbox, no abs, plenty of traction, no power so if you get a corner wrong you cant just step on it and play catch up...it was about a little bit of a gain on every corner apex and so much fun trying to go quicker and quicker...because it could simply go so deep under barkes, be turned in so much later and still make the apex
I cant see how something like an R500 woulnt be a blast, competitive and rewarding to drive. After driving one in semi anger i am less excited about trying to go fast in a steel bodied production car. (as a driver) But to spin the tools on one i still like the idea of getting the same car you run to the shops in to be quick.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
