I am seriously looking mate, in conjunction with a close friend. The car is good, it's me with the mental barrier.
Also, as I'm not at all familiar with the things, my big concern is running it against the known contenders, only to have a protest lodged for something that I wasn't aware wasn't factory or legal.
At least with a Datto I really have no one to blame except myself.
What's the deal with importing race/rally reg cars from Europe? Assuming the 12 month ownership rule doesn't apply, but is it very difficult and are you able to get rally reg on them here?
Lets talk FWD... Lol! I reckon Snowman should get back to the idea of a Scirocco or Gti-R Golf or something.
They are also on my (ever growing) short list! Well the Golf R and the Scirocco R are anyways.
The list as it currently stands is
Rebuild another GTR
NSX-R
RX7
Louts Esprit (thats the Brisby coming out in me).
Or go something newer like the TT-RS or the VW option. The new car thing might appeal if I can also make it an Enduro car for Bathurst 12hr.
The only thing I do know is doing something with the 35 doesn't appeal. And neither does an EMO.
I have a frustrating hunk of engine-less metal and a Porka hankering! :cool:
Ben: Have you known anyone who's done it before?
I don't know the exact details Dane, but people do it all the time. Quinns GTR's spring to mind, both imports from NZ.
Just on the TT-RS, what an impressive piece of kit they are. A friend of mine is wanting to move on from hid genuine 996 Turbo S, and I think I'll recommend one of these new Audis. Very impressive and sound mint. :(
Given that this year both Matt and Maher's cars were showroom + a flash tune I'm sure there is a lot more to be seen from these cars in the future.
I did say to Matt at Lake Mountain that they would become the new EVO once people saw what he did in his! But I rate them highly. 1300kgs FTW!
Thats where you are wrong! :( I so wish i could have afforded to lose the 10,000pound bond on the R400 last year. Would have been great to have a real go and use full revs at Spa in the lesser R400. They are so much fun to drive.
Tricky pedals, gearbox, no abs, plenty of traction, no power so if you get a corner wrong you cant just step on it and play catch up...it was about a little bit of a gain on every corner apex and so much fun trying to go quicker and quicker...because it could simply go so deep under barkes, be turned in so much later and still make the apex
I cant see how something like an R500 woulnt be a blast, competitive and rewarding to drive. After driving one in semi anger i am less excited about trying to go fast in a steel bodied production car. (as a driver) But to spin the tools on one i still like the idea of getting the same car you run to the shops in to be quick.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
