The way I read the rules it's any E85, as long as the 85% of ethonal is from CSR. "CSR Ethonal blend" is the wording from memory.
I'm hoping that's right, cause the Powermax is cheaper than the CSR (now Sucrogen), and uses CSR ethonal
Did you mean Power Plus?
Right now I can find 4 suppliers of "racing" E85.
Power Plus
Cheetah Race Fuels
Elf Race Fuels
Fuel Control Australia
But you can also buy the non-racing (basically 91RON mix rather than 98RON mix) from a couple of local petrol stations.
I guess it would be tops to know from that list what can and can't be used.
yeah that's the one. From what i know
Power Plus - 85% CSR Ethonal, 15% Power Plus 98 - $2.30l in tassie
Cheetah ?
Elf - ?
Fuel Control Australia - official CSR E85 (now Sucrogen) - $2.50l +postage to tassie
Phuck bolts, too heavy.
Zip ties and black Sika is where its at.
black sika? forget that, just get into some black nikka and you will think chewing gum is all the sealant you need... my nikka.
that RX7 is not a bad piece of gear for $35K providing the engine is a good one. it would be a great fun circuit car or a pretty lively tarmac rally car.
also on E85 there is also a local sydney supplier now who is selling E85 with the CSR ethanol but blended with BP100 RON premium petrol instead of 98 pump gas. if anyone is keen send me a pm and I'll put you in touch. price is competitive I think and can deliver drums of various sizes.
Ric know's how to build them, and with his mullet powers he can race them too
yeah those more cost effective E85s work under the regs.
for THC mark and the team at race fuels will be doing e85 fuel service http://www.racefuels.com.au/, and there is a 98ron servo on the coursewe cross over twice daily (well prettty close on sunday anyway).
touché... both the red and silver ones!
word on the street is they're right up there with white gts-t's :)
actully it's better than mine, i just got 0km/40l when i emptied my tank. The fuel was so stale it wouldn't run a lawnmower
Good to know - thanks Stu.
Spoke to Mark this morning and the Elf E85 is selling here for $2.20/L - best rate so far I've found for 98RON blended E85 - and will also be available as an on course back up for THC anyways. Hopefully it goes well and we see them back as another supplier in Tas 2011 as well.
Devonport Tyres are the Elf boys... spose mark is using this to get rid of all the elf98 that they have laying round? Scott or Dean @ DPT&F (03) 6427 0700
So I took Newtons EMO 4 for a spin up at DECA on the weekend.
Easiest car to drive fast I've ever driven - by a long way. Quite scary really.
I've driven lots of EMO's over the years but that was the first one thats made me think twice. The challenge now will be to make my new toy as close to being that good as possible. But it was a real eye opener into how good a pretty basic, low powered car can be. But it was a good lesson in that an easy car to drive fast is better than a fast car. It's just easier to build a fast car than it is the other way around!
I heard on the grape vine today that a Western Australian father of a former Joker is planning on building a number of homologated super EMO's with stroked engines, carbon fibre everything and sequential gearboxes to run at Targa 2011 with his #1 driver moving from the R35 to the new car.
Apparently you can have one for a cool $250K (or less if you provide your own "donar" car).
I really need to get onto this Racepace GT-R concept before this window gets closed!
I concur. I think factory specials are ok but workshop specials are going a bit far.
But where then do you draw the line with things like the Skelta's / Daytona's etc.
It's all too hard - but the big boys with the cash are sure going to exploit it whilst they can I guess. Perhaps TQ will see if there is some way to homolagate his RSR.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
