On topic, YT was telling me today how quick some of it is :P Double wish I was there I love the flat out in top gear stuff through real quick corners. :blink:
Also told me of the lack of guard rails.... I nearly pissed myself when he told me he changed some notes from "Triple Caution" to "Westpac"..... As in rescue chopper. Haha
Ha yes I think we might see some rather spectacular off's for THC compared to the usual Tassie ditches, slight hills and field plouging - although upside down in a barn will still remain my favorite. Lets hope everyones safety gear is well in check - there are comments every snow trip how dangerous those roads are.
I know they're not Nissans, I know there is a video thread, I hope it's not a re-post, but I was literally agape at this video. Hope you enjoy it too.
http://www.youtube.com/watch?v=kEOKck7WWvU
Actually that was me. The car wiggled a tiny little bit - mainly through the steering wheel - when we hit some standing water and I wasn't expecting it - but at 200km/hr it gave me a minor heart attack!
I think I would have pulled over and walked the rest of the stage after that!
saw your new car yesterday... VERY nicely put together bit of gear
Dan there is only so much we can do in a day given the distance from home.
I've worked out if we head up - drive each stage once and get some footage of it - then head home we still have to cover over 700kms in the day! It's going to be hard to do any meaningful recce without spending a whole weekend up there - which unfotunately is something I won't have time to do.
We're going up for THC Recee on Oct 23 and will HD video all the stages from my 993 Turbo. I'll upload some if anyone is interested just PM me.
Edited by martyboy26
I drove through a lot of the stages yesterday, after a days racing at Winton in the R35,
My car is a total mess after more than 25 kms of muddy dirt roads between stages
Don't think I'll both doing it after seeing the state of the roads
Day one is OK, just a bit dangerous in places, good roads thou.
Day two is just remote wilderness
Makes Arrowsmith look like suburbia
:laugh: Sounds like the Turbo will stay in the garage for Recce. Looks like the Pajero it is!
For anyone wanting to drive over the 28 and 10k stages on the Jamieson Eildon Road I certainly wouldn't take anything too flash as there is 14km section of road construction as detailed in the recce notes.
The 14kms is now 1000% better than it was just four months ago and will continue to be improved. There was hope of it having a seal on it for the event, but too much rain means it will more than likely just be compacted road base and only partly sealed... for 2012 it has potential to be the longest targa stage we've seen.
Jeff's right, on these two stages there are no houses, no business, no nothing... but we do have excellent communications, tracking and incident response!
Sorry if I sounded a bit negative about day two stages
I was very tired after a long day at the track (I'm old remember)
It was all a bit of a shock in the dark and running out of fuel
Maybe it will look better after a second drive with pace notes in hand
I think that the dangerous bits on day one will need tape along the road edges
to find where a car has gone off
it's a very very long drop into that valley
Anyone else been through there yet??
yeah there are some big drops that will have everyone's respect.
a lot of people have been through so far and some great feedback.
have you dusted off the two ton pussy yet?
I thought that the "two ton pussy" was not allowed back as we don't qualify for legends status because we have competed in the past 10 years,
although I would have thought that as this is our 18th Targa we must be getting close to legends by now.
14 years since it ran and we still get asked at most stages every year..... where is the "Two Ton Pussy"
and yes it is very dusty
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
