Thats a curly one, I'm assuming the rule along the lines of "no modifications to the bodywork can be made" is the issue?
Personally, I'd roll the gaurds. If someone wants to protest that, let them go I reckon! lol
Yep thats the one!
I know Adam Newton just got a non-conformance issued by the powers that be for rolling the guards on his EMO 4 as he tried to fit 9's under his car.
Yeah speaking with Mick today this is where the alarm bells have come from.
The issue was with the guards. But it looked modified as they were rolled a lot.
Mind you - they seem to be out to get him for some reason so maybe others would get away with it no problems. But Adam is having lots of fun currently because he's quick so he must be cheating.
But I just thought I'd mention it.
Yeh I did figure it was partly because he has proved rather competitive. I very highly doubt I will get the same sort of attention lol!
You only get checked if your in the top 3 of your catagory. But if your car isn't right, and you do a Bradbury, you could get pinned (although the last Bradbury didn't get looked at)
If its a rule enforce it, otherwise don't make it a rule cos no doubt someone will cheat if they can get away with it.
Shit I can remember in 2007 coming 2nd last in the rookie due to smashing a rocker arm and cam on day one, we still got pinged for illegal strut tops at post event scrutiny.. Ah the CAMS scrutineers were certainly anal, but thorough none the less.
Front is Nismo 1.5 way. Rear is Nismo 2 way. This is the same set-up as the old car.
Anyways - doesn't matter for now. Tomorrow we are putting new arms in the car to get the alignment right (Thumbs up for that rule change). Will take it for a drive and see if that makes any noticeable difference in feel. If not I will try swapping back to the original non-V 4wd computer. And if that fails will pull the rear diff out and play with that.
After that it will be time to look for the matches!
well it sounds like you will figure it out. and I know the feeling about the matches mate. sometimes they will just not run right and no amount of logic will defeat them!
you wanna talk anal, we got pinned for having the wrong model dash,. in a gemini!!!!!!!!!!!
they need to worry a little more about about stroker engine's and dog box's, and little
less about rolled gaurd's, and people who lessen the spec of there car to make
them cheaper to build and run..............
Edited by Burgz32
Yeh its a crime when it comes to stuff like dash's and grills...
Dogboxs are legal now in certain categories, after spending a bit of time in several cars with them you would be crazy NOT to run one!
Was the non-conform issue due to running 9's on the Emo or the guard roll mate?
Adam sent some pics through. The problem seems that rather than "rolling" the guards and maybe getting rid of any lip protruding back into the wheel arch, Adams are more what I would call "pumped" :) The arch has actually been dragged out a bit. Hats off to him though for asking the question up front, although it sounds like he needs to as once you do as well as he is at the moment, sadly a few seem to assume its got nothing to do with talent and all to do with an ineligible car. He is a bit stuck as it is a little hard to undo the work, especially on the rear guard.
With EM you can go up 2" in either direction on wheels. Not sure what the IV came out with but he had got the nod to run the 18 x 8.5's he was planning to run. Unfortunately the IV unlike the V and VI didnt get the plastic wheel arch extensions on the rear and wider front guards so he has come unstuck on body clearance. The VI will swallow 9's no problem. Given the rules, personally I am contemaplating some 19 x 9.5's for the evo and maybe drop it on its guts. Its all about the look right??:)
Fresh set of yokies went on rims yesterday so can now be used to measure and keep rolling to a minimum.
Don't forget 185 semi's for da fulli sick tyre stretch!
Yeah I'm pretty certain that the lil Evo 4 ran 16x6.5" standard. My mate David Catchpole ran one (in Targa) on stock wheels and the thing was quick. Catchy's quick too I guess.
18x8.5 is massive for an Evo 4! lol
Edited by Marlin
Indeed he did..... good enough to win Rally Burnie 2006 outright in front of Jimmy remember :) .... with him missus navving for the first time :)
Matter of fact.... here's the acceptance speach!!! LMFAO :D
("Big Den" is Whitey's dad) lol
http://www.youtube.com/watch?v=qq_09-bGxTg
Edited by Marlin
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
