If you're a Ford man what about a Sierra XR8. Something a bit different..
Or to carry on from this previous thought, if you want something completely different, what about a Rover Ventura? Rover SDI with about 2 foot cut out of the middle and a 350 Chev chucked in the front?
One for sale right now...(I think the rand is about 7:1!) http://www.junkmail....427QYEdQX201107
My South African mate is trying to remember more of their oddities, but to quote him "it was alot of beers ago".
Finally seem to have the ability to reply - woohoo!  Had all sorts of trouble with my iPad and this forum, but found a cool app that seems to work... Sort of...
So I wanted to stop this nefarious rumour The Woo is trying to spread .... It seems that merely enquiring after another's interest in an event constitutes entry (if only this were true).  Boy I had a lot of explaining to do to my husband (pool heaters)
The closest i will get to being at Classic Adelaide (or any other event in the foreseeable future)  is if Kel takes up my offer to be her groupie .... And even that's not looking so good right now - I hear I need to slay her other groupies to be considered at all, as she has set up a master chef / DWTS elimination style process
(now counter-rumoured, my work here is done)
Mel
I might end up a groupie myself Mel - I've offered to run as part of a package deal with a Just Jap car if it makes it down there so will see what happens ;)
bummer snowy. it was your ultimate 34 after all the stuff you learnt with the builds you did on the blue car. seems pretty fair on price for a very freshly built and very competitive 34. it's only really been completed for what 6 months or so? most people getting the chance to buy a full built car are looking at ones that have done a good few years of comp and really need a overhaul.
the real question is then what are you going to replace it with? super lambo? is there any use in a GT3 or 911 turbs these days? I would think a 997 turbs would be a good thing with awd and bags of power and torque. tyres maybe be an issue though but jim seemed to manage ok over the years.
or is a full on R35 GTR the go? maybe vspec or the RC spec etc?
either way I hope it goes well for you mate. greatly envious of whoever buys the 34. not bad to buy into a car that can run up the front in EM for $70K. and still rego'd so you can drive your mum to the shops in it too.
The problem with the Turbo's is the TCM and PASM does not switch completely off. Even when off, they still interject. Porsches stance on this is it is not a motorsport car, thats what the GT3/2 is for.
Jim said it was dangerous when you pushed it hard, any amount of slip in the rear and the Engine would cut out. and I remember Tony Alford/Tony Quinn both got 997 Turbo's prior to R35's and both said the same thing aswell, and that Porsche was not interested at all in reprogramming and/or disabling the TCM/PASM.
^^^ Good luck with your sale Snowflakes. As said, the price seems to compare well with the other tarmac 34's, and your has all the best kit on it and is a proven performer.
EMO is sold at my end. Gets picked up today. Was obviously too cheap. ;) Time out for a little while but will probabaly follow a different path to Snowy and head to classic with something from Japan. Would love to try modern in a 35 but just dont have the wallet. I do like Stu's suggestion of the moffat spec group c 13b turbo RX7. With the freedoms of MS you should have a pretty light and powerful car on your hands. And they dont look half bad with the flares and front and rear treatment.
    • hello wanted some insight on what my problem could be so i swapped a RB26DETT into my r33 gtst used a R33 GTR engine harness and im using a haltech platinum pro. The car cranks but no start the ecu isn’t getting any power now im trying to find out why i cant seem to find any schematics  or diagram for the engine harness for the r33 gtr anything helps thank you.
    • hahahaa @GTSBoy that is my last resort. Like use a cardboard and cut it using the indicator as a reference. But I was winging my luck to see anyone had a spare bumper because drawing the outline off the hole is always easier and less chance of mucking it up
    • Admittedly in that screenshot its doing about 13psi but later on in the log theres definitely spikes to 16. What is missing though is the massive peak, then a big drop and then a recovery. While it does go a little higher than I would like on base pressure, I think it's reasonably safe to assume that boost control via the mac valve should be a lot easier to control from here on out. I wasn't game to hook up the mac valve today as it's very wet and it's on the verge of fighting traction as it is.
    • I think this is still wrong. There is something crappy with wastegate priority (or the f**king absence of it) if you can't get below nearly double the base spring pressure. But if you're happy with what you've got, upload skid vids now.
    • So a further update for this one. Turbosmart were very gracious and took one look at the wastegate and said this is our original version, we will just replace the entire thing and send it back to you. So I fitted the new wastegate with its new revisions and took it around the block on spring pressure (9 psi spring). Appears the minimum it will do is about 16psi. Keep in mind this is only 2nd and 3rd gear pulls. I think the issue is fixed compared to what it was doing before however I'm happy to provide more logs if anyone thinks theres more to the story to uncover
