wheels of choice for a 32/33/34 gtr in targa with bigger brakes?
I have alcon's (365mm) and heard nightmares of finding wheels that fit over the caliper
obviously would have to be 10" wide or less to be legal. no idea what to do with my weds 10.5" rims.
We ran the 365 Alcon package under 34 wheels, you can see there was some issues with foreign object clearance (always is with big brakes and rallies) but they cheared fine.
Wheel is dependant on whether it is a 32, 33, or 34, as they obviously all had differing sizes from factory.
The supp regs clearly state for Early Modern;
Early Modern & All Classic: Wheel diameters may be varied by a maximum of plus or minus 2” and wheel width varied up to 2” from the standard dimensions. Classic vehicles may only increase sizes up to maximum of 18 x 9 inches.
So, R32= 18x10's
R33 = 19 x 10.5
R34 = 20 x 11 (full hectic)
Edited by Marlin
So, R32= 18x10's
R33 = 19 x 10.5
marlin, R33 would be 19X11. as they had 17X9 stock.
it goes:
R32 16X8
R32 Vspec (some run as this I believe?) 17X8.5
R33 17X9
R34 18X9
so just add your 2X2 to those.
Yeah you're right Baron.... I knew that after I posted it, but you got the drift ;)
It used to be 1 + 1, We had to run 17 x 8 on my GTS-t, now we have 18 x 9 which makes me happier trying to catch the Evos (in the dry at least) :)
32 vspec was 17x8 - so 19x10 max not 10.5.
The +2" wheel width is one of the worst things about the current rules....everyone has to spend more on tyres because everyone does, and the crashes are harder.
Blaise reckons one of his biggest advantages was being able to run bigger rubber than the rest of the EMO's (he squeezed on 255 rubber onto his cars where as the others were all on 245's).
The funny thing is for me my tyre choice was the Yoki A050's and the biggest they have been making is 265's. I have a set of 10.5's and a set of 9.5's and I personally found that the A050's in 265's sat better on the 9.5's than they did on the 10.5's (where as the RE55's and DZ03's were both better on the 10.5's in a 265 tyre).
But as soon as the 295's were out I'd have been switching to them on the 10.5's as my preference.
^^^^ My gut feel on the rubber issue, was the bigger tyres gave me more rubber to wear down so hopefully longer tyre life. Made me more confidfent of getting to the end on the one set of mediums. Turned out tyre wear was definatly not an issue for me, but it is a light car with moderate linear power as opposed to the heavier GTR's and bigger HP.
But for outright pace, I did do back to back testing between 235's (what most emos run) and 255's on the same day and there was two tenths of stuff all in it. I went about 0.4sec a lap quicker at best, but also had gone from worn 235's to new 255's so not sure if most of the gain was just that I had fresher rubber. Wasnt a massive improvement, but at the same time cant be a bad thing. Most forms of motorsport if given the opportunity, tend to run the biggest rubber they can.
Greg Garwood is looking for a good tarmac prepped R32 GTR if anyone knows of one?
Yes, I've told him about Jurgenson's and I'm sure he'll follow that up. - edit - Drew doesn't wish to sell now.
Edited by Marlin
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
