^^^^ That would be great Mark. After having just spoken to racing beat in the US about building a motor for me I am not so sure I want to sell all my organs plus any furure unborn children to have one of their engines. I am sure they are top notch, but circa 20-25k for a rotor engine build (complete long motor with turbo etc) is a bit beyond my budget.
But at the same time, happy to spend decent money to get something I hope will be reliable. Tassie is just too far to go for me to have a mechanical early on.
While RB did have a bit of a tech edge in the past with screw in ports, cooling mods to housings and so forth - even if they did use their alloy plates, ianettis they usually recommend, 2 piece eccentrics and so forth, that's well OTT.
consider going japanese? they know how to make a good rotor motor. had my FD RZ's motor built in japan at a shop called pre-stage. was bloody quick (in build time) and performed very well. Cost was reasonable too.
There's no secret sauce in any country - although some of the locals practicing the art here probably would have been more suited to wild west blacksmith occupations. Your ex-RZ went ker-blammo very shortly after the sale.
I am suffering the same thing..
i am really trying to get excited about building an early rotor to run in classic but am finding it hard to get really excited about it. Probabaly should have just kept the evo :(
One of the long time classic rotor guys did the switch this year, damaging the now 30k + Rx3 probably the turning point. There will be someone else doing the switch too next year.:whistling: With the price of rotor engine parts going through the roof, you can basically get 4 cylinder rods and forged pistons with change for two new rotor housings.
If you want to persist..... it's no Rx7 though.....
http://my105.com/lis...ls.aspx?id=3467
Hearing ya Ben. Advice I was given very early on was don't head to Targa with anything you can't afford or risk throwing in the bush.
Funny thing, guy I mentioned some pages ago with the GTR, ended up having to make lease payments on two cars after writing one of them off at TT.....when these were worth a bit of coin too.
^^^^ There are just so many ways to crash at Targa and sooo many variables. Even with the best intentions, some rain and a fluid spill or something else unexpected could easily have you off the road.... and then there is always the red mist to contend with if you get passed or are getting caught.... :)
bummer 2pee. didn't know that! :(
the RX4 on my105 looks pretty good value. especially with 2 engines and another in bits!
but yeah rotors can be a whole lot of pain. but when going well they are great.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
