The problem is as I see it that if you limited it to 4 tyres then everyone would have to run Dunlops as they make the only decent hard tyre.
Maybe that's not a bad thing for parity sake but it is nice to have the options available to you.
With an R35 4 or 6 tyers would mean the OEM Dunlops but 8 tyres would allow you to consider the Toyo's as a option for either one or both sets because they are heaps better in the wet.
TWP stage results on link below.
Off to a fairly predicable start. YT leading modern with Sims and Captain Fathom giving chase. Reeves also not too far away in his first outing in the chook cooker. Emo VII's of Rickard leading with Warren not too far behind in EM with O'Keefe giving chase in the datto.
http://www.rallyresults.com.au/targa/TWP2012/showItineraryt.asp?paramVal1=1&paramVal2=&paramVal3=1
Sims off, Quinn with "ABS issues", bring Captain Fathom into 2nd behind YT! Great stuff.
Qld mates Millar/Dean leading Showroom, good buffer over Evans. Keen to see if they can keep him at bay!
And another SAU member Matt, aka "BlueGTR" leading Early Modern with my great mate Squeak sitting beside him.
Great stuff!
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
