yes it will. there is a ticket open on the feature/bug tracker to add ability to save the trip statistics. it would probably be a third screen (so 2 trip ones, one showing current trip, and one showing all trips) that shows your total recorded trips.
reason why it hasnt been done yet is that trip data would need to be saved to EEPROM, which only can be written to a limited number of times, and the display doesnt know when you will turn off the car. so need to do some tricky wear levelling to spread the writes to EEPROM out over the fully spare eeprom, and to only update the trip data every say 30s.
but yeh i really want this feature myself too so will try to get it done when this first batch is sold and i have time to work on it.
Would it be better to get that mini-SD port going...? Data logging? :P
  • Replies 82
Posted Images
Got my display a week or so ago, installation couldn't have been easier. The information you can access with this little unit is extremely useful - thanks Peter, my Stag' now has what it has always lacked - a tripmeter! Now my mate with the R31 Silhouette can't say his has more features...
nothin yet for the microsd, dont expect anything too soon for it, a few more things will come first (hopefully saving trip meter onto a global trip stats screen or similar).
Cool ;) Will be watching with interest... fantastic little unit.
BTW, can anyone confirm: is 380cc correct injector size for series 2 stagea (R34 RB25DET)?
Some sites say 370cc some say 380cc, but you will still need to calibrate it as there will be a +/- factor. Ive been waiting until I do a long trip, fill tank, reset trip, drive, fill tank again and check fuel used against fuel pumped in, assuming the bowser is correct. The longer the trip/more fuel used the higher the accuracy will be, or even do over several long trips, noting fuel used/fuel pumped for each. i wouldnt measure it over many short trips as the probability of error will be increased. Do some quick maths and adjust the injectors accordingly. About as accurate as we can get outside laboratory conditions, temp/bowser calibration etc.
right on the money. and make sure the display is on one of the two main screens nearly all the time (eg if u go to main menu it stops recording fuel consumption etc until you go back to main screen).
this will be made easier once i do the global trip meter statistics stuff so it saves stats from each session so u have total fuel used etc. until then you need to rely on a full trip with filling up both sides and dont shut the car off (or write down fuel used before you do) on the way
Just thought I would ask, in your next version, since you have MPG, can you include KM/L in the trip stats ? as this is my preferred econ format. thanks
sign up and add it to the bug/feature tracker on the site...but i dont think itd be high priority...its like yanks asking for GPM, who uses that?! :(
Cool, good idea. Will be doing one of those shortly... to Victoria
lol :laughing-smiley-014:
ok so ive been working on microsd logging this weekend (theres stuff i should do first, but oh well!) and theres good and bad news.
good news is ive got extremely simple reading and writing going (as in write 80 numbers and read them back), so its possible.
bad news is that i could only get it to work by adding a resistor to fix a too high voltage going to the card. see attachment. if you cant solder then you could probably even just mechanically attach the resistor (being careful to only attach to specified contacts) by winding legs around the existing component legs and then cutting short.
and the writing wont write in fat file format so u wont be able to use your card outside of the display without reformating it. you'd download logs with the usb port and some form of downloading program i gather.
for read/write speed, its about 30KB/s (512 bytes in 15ms), which should hopefully be enough (thats at 100% of the cpu's time, which wouldnt leave time for anything else. but we only need ~5KB/s so should be ok)
I bought your consult cable, which works a treat. Have you ever thought of doing similar to this for the wrx's? I own an my03 as well and would do dirty deeds to have the same capabilities with it..
Easy done! :P
Edited by wisey18
for $300 theres the subdatascan s2 (google), although its only got data display/peak values (and rs232 passthru) so naturally not as awesome as mine, but being newer tech the subarus have some nifty data available like boost, intake temp, ignition retard (level of knock?). and of course you guys with OBDII have all the OBDII stuff like scangauge so you're all set!
i have my eyes on getting maybe a 03+ wrx in a few years, doubt ill be making anything non-nissan until then.
Did some highway driving over the last few days (about 2,000Ks), without cruise-control (so speed was not exactly perfectly constant) plus overtaking etc. and I noticed that the average trip speed would sit at 110km/hour... which seemed too exact? Does the unit show average speeds above 110?
Edited by DaveB
im not aware of any reason why it wouldnt...do you think you should have averaged higher? (i havent driven far enough to get past more than about 100 or so average due to slower local roads etc).
fyi the reset on options menu can be used to do the same as unplugging/replugging in display (it doesnt reset saved data/settings). so perhaps if you have someone that can reset the display once you're above 110km/h and see that it is averaging correctly.
also a good writeup on microsd resistor mod (that ive emailed everyone about) for those who are at id less than 65 on the list:
http://forum.pulsar.org.au/showthread.php?t=79971
v2.01 firmware is now available on firmware page. has sequential and random speed tests for microsd cards (and capacity/info as per 2.01 beta), no actual logging yet, but you can test out microsd cards you may wish to use for logging.
note, as the lcd will tell you, you'll lose any existing data on the card if you do the speed test.
if ur going to use a card, buy one just for this, because it wont be windows/pc readable, and to read data off it you wont remove it, but use the usb cable and some program ive yet to write to download the logs.
there is a howto guide for those of you (displays sent out before september 3 - i.e. id 1-64 on the list) who need to do the resistor mod here. those people ive contacted via email a couple weeks ago
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
