If your taking the wheels off to paint them (presuming you are as i cant think of any other reason to remove them lol, sure there are plenty tho) you can just give the back of them a slight whack from the back with the handle of a screwdriver or something similar. that will do the trick
Just use a Flat Head Screwdriver.
There should be a little gap to allow you to fit the screwdriver in and hinge it out.
Thankyou soooo much, jst got them off!
must explain: on my old r33 the rims needed a large plastic nut remover and i thought this was the same
I jst got the rim off and the tyre was punctured by a screw, ill take a pic and post it a lil later.
I wasnt gonna paint them
Cool!
Did your R33 have stock rims? Or aftermarket?
If you needed a 'Large plastic nut remover', I would assume it was just the design of the wheel... Cuz standard rims just have 5 nuts / bolts...
lol i thinks its funny someone who buys a r34 gtr, cant get centre caps off lol
G'Day Bryn,
Johnny has already been PM'd about a plastic tool made for Advanti Wheel Centre Caps that fits the R34 GTR centre caps perfectly. This way, he doesn't scratch the caps with a flathead screwdriver (unless of course, you wrap the head).
Good tool to have 'cause the shaft elbow has just the right angle and thickness.
Cheers, T
Ah yeah those wheels, I have seen them before.
Like I said, probley just the design of the wheel.
They werent bad, bit heavy though.
On another note, the flat tyre i had was caused by a tiny nail which had embedded itself right in the centre tread and caused the air to slowly be released (exactly why i never actually knew about it on the road, it was in my garage when it deflated)
I took it to the tyre factory to have the puncture repaired, cost 20bux and all but 5minutes and my tyre was fixed which was a relief to me, cos i didnt want to have to buy 2 new tyres (especially these bridgestones)
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
