My r33gtst is running 18psi and 247rwkw.
I have been using BKR6E plugs and just started getting misfire above 4000rpm.
The plugs have only been in about 12,000km. However, I have had a dyno tune and 1/2 a track day on those plugs. The plugs still looked ok.
The misfire is now completely gone and the response is back in my car. Heaps more power.
Replaced with the same NGK BKR6E.
I suggest changing every 5-7,000km.
Anybody know how long the iridiums last before a loss in power?
It's not the most fun job changing them but only takes me about 1-1.5 hours now..
If running less than 14psi you probably wouldn't get the misfire as quick but you are probably losing power by not chaning your plugs.
Edited by benl1981
https://www.sau.com.au/forums/topic/228734-importance-of-changing-spark-plugs/
  • Replies 43
Coppers have never really lasted longer than 10,000kms, and should be changed every 10,000 or sooner, just do them everytime you change the oil.
1.5hrs to change plugs is a bit of time though, i could do it faster on my 25 and i dont set a blistering pace... and the 26 is faster again for obvious reasons.
Iridi's generally dont last as long as they say unless in a stock car.
But with tuned cars, more boost, higher temps and everything else associated etc etc, the reality is they dont last anywhere near that.
So stick to coppers, change them at least every 10thou and live happily ever after, its pretty much a given, surprised you didnt realise that :)
the way i see it is that the coppers should be changed atleast every 10k, the iridiums say every 100k, lest just say that the iridiums only last 70k, the coppers are what, $2-$3 each, lets say $2.50, iridiums are about $15 each, so each change is costing you $15 for copper and $90 for iridiums, but you have to change the coppers 7 more times than iridium so really it cost $105 in coppers and a lot more time spent changing then, even lets say that you only get 60k out of iridiums the money breaks even but your saving a lot of time, even if you only get 50k they only cost $15 more and still save you a lot of time.
i know what i would prefer to be doing, and its not changing plugs all the time.
And this equation is assuming you do the coppers at 10k, which would probably be strecthing the life of them, where as 50k is not stretching the life of an iridium.
Edited by W0rp3D
They would have needed changing after the dyno tune.
Platinum and Iridium plugs do last longer under normal driving conditions compared to copper but they all pretty much degrade as quick as eachother when put through heavy work on a dyno or on the track.
Depending on how often you go on the track the best bet is putting a new set of coppers in and let them cop the abuse of the track day, throw them out after and have a dedicated set of street plugs so that you can be confident you're not losing performance to over worked plugs on the street.
Irdi's wont last 50k, let along 100k in a well modified car, thats the problem.
Coppers take a beating for thier life whilst the iridi's will foul much easier. Do 10 cold starts with short drive in a row (ie, trip to the shops and back) and you can foul em that easily.
Say a fuel reg dies, in 50k, easily could happen, iridi's dead.
Fuel pump gets a bit tired, again, iridi's dead
So many things to destroy them, when what does it matter if your only using $15 worth of plugs :)
Soon as you kill one set prematurely of iridi's you've lost the money on them right then and there.
I killed a set after 20k (a few years ago now), never gonna do it again @ nearly $100 a set. Not worth it for a modified car.
Stocker = yeah probably much more viable and id go that route if it was.
lol ur worrying about $100.
never had an issue with mine and been using for some time.
I have checked them every 5k and so far no issues with the iridi's at all after 10k.
Personally for $100 every 10k or whatever I couldnt give a toss. Although now you can get them online much cheaper now
I guess i've never noticed - running only 10psi before I think I got about 20k between changes, without even getting a miss.
Probably about 1-1.25h is realistic . But I doubt you'd get much quicker than that when you have to take off strut brace, intake pipe etc and then reinstall. I reckon a workshop would get you for a good 1.5-2 hours..
PS. BKR6E come gapped to 0.8mm. I checked them last time and all good. This time I didn't bother.
Edited by benl1981
1+ hours to change plugs??? wtf are you guys on?
takes me 20 mins max, and yes i have a coil pack cover on, still with cross over pipe etc.
I run coppers, NEVER had a prob with them much prefer paying SFA for a plug rather then 120+ for 6 of them...
ok quick noob question... sorry to hijack thread..
but my r33gtst misfires like crazy aftrer 5000RPM.
I changed mine about 5000ks ago (the iridium ones) but it still does it...
how do i gap them to 0.8?
can it be the coil packs? its driving me crazy... just saps the power...
Edited by usmair
20min if you having a beer at the same time... LOL
Buy plugs that are 0.8 rather than regapping 1.1's (most 0.8's are the same plug number with a -8 at the end). Many misfire problems are caused by aged coils, spend $500 on a set of splitfires and you will be amazed at the difference.
On a side note, when I changed the plugs in my Toyota Hiace at 100,000km the guy tried to sell me Iridiums as they are the factory plug that Toyota uses due to the difficult location on the engine. I handed them back and bought a set of coppers and ran them for an entire 100,000km without any issues at all. I've now run a second set of coppers for 103,000km without any problems :)
You're telling me you can't change your plugs with the strut brace on? Do you even KNOW how to use a socket set properly?
I've done mine before with the intake pipe still on there also. (Yes, straight over the motor pipe!) they're piss easy, and DO NOT take 1 - 1.5 hours to do!
I find it takes more time to work around things than take them off in most cases. I forgot I had to look for missing tools so maybe closer to 40mins but I have a look down each spark plug hole with torch and guess took my time a bit.
You guys must be pros :0
do it enough times and you'll be a pro also....
i had my car dyno'ed a while ago and had missfire issues... by the time we sorted it out i had the plugs out and back in 3 times in that single day. seriously its not that hard once you have the right tools in front of you.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
