Just a heads up that the enduance racee is currently underway. GTR isn't looking too good, I hear it pitted within the first hour dropping from 5th to 13th then down to 17th. If anyone can understnad the update on GTR-world.net which is in Japanese, please give us some info.
https://www.sau.com.au/forums/topic/228879-tokachi-24-hour-race/
They make them now... At least in prototype form.
The GT-R is still battling away. Been a few more problems. Drive shafts had to be replaced. Then all the hub bolts broke on a rear wheel but they made it back into the pits some how. Both were fairly long pit stops though.
Still out there now clawing its way back up. In 21st place now.
Update anyone?
As Giant says, hub issues likely a human failure. Unlikely that faults like that get through to production.
....... although, now I think about it, bug-eye STi with failing front hub bearings after about 6 hrs racing anyone?
I was at the race for the weekend, just got back. Got to say the GTR was pretty dissappointing. It belted off the line from the rolling start, held 2nd for a lap and then it was all down hill from there, lapping at least 7 seconds a lap slower than the front runners.
It looked great but honestly it sounded like a semi stock exhaust compared to everyone else, overall it was good to see it out there belting around. Thats the 2nd one on that track since late june, one of the HKS customers had theirs out for a track meet a few weeks ago.
I got a few pics and bit of vid that I`ll post up tomorrow as I`m rooted, couple hrs sleep and 5 hr drive home. Pics are nothing flash but got some good carpak action which I`ll post up in the japan page tomorrow as well.
Edited by elrodeo666
Awesome that you were there. I personally wish I had made it out but travelling just for this race is an expensive luxury I couldn't justify :D
Anyways It's a production car in a Super Taikyu race. Not to mention the tires handicap. 7 seconds isn't so bad. Lot's of dramas and unknowns going into the race. Next time they'll know a lot more in terms of what to expect and what to keep an eye on.
The exhaust was basically stock except for cat removal and tips welded on.
I'm surprised the brakes looked so good after they pulled them off the car.
I will explain it all in a sec in detail, gotta run to the shops but in a nutshell the number after the letters denotes the engine capacity. The letters denote the class.
ST = Super Taikyu
EC = Eco Class
IP = International production
4 = 3000cc and over.
Pics not too crash hot, only had my misso`s camera but something anyway...the grey/black GTR was from about 3 weeks at a clubman event we had Tokachi Speedway.
Theres more pics in japan section but of show & shine
post-43319-1216717689_thumb.jpgpost-43319-1216717653_thumb.jpgpost-43319-1216717587_thumb.jpgpost-43319-1216717553_thumb.jpg[
ttachment=172556:IMG_0455.JPG]post-43319-1216717475_thumb.jpgpost-43319-1216717429_thumb.jpgpost-43319-1216717361_thumb.jpg[at
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
