NEXT MEETUP!
When: 31st August Sunday
Time: 2pm (yes im lazy..)
Where: Rouse Hill Maccas! (behind the Fiddler)
Whats happening: Meet up at 2pm, leave around 3ish, then cruise to Galston Gorge, then back to Thornleigh for more Maccas perv..
You guys should know the drill, wellll.. my drill, so no emos, ugly cats, bollocks...
And babes are allowed :rofl:
So Whose In!
https://www.sau.com.au/forums/topic/229285-hills-area-meetup-3/
  • Replies 239
Posted Images
Im in.
this time ill seriously run over those cyclists.
Ryan knows im not lying.
i love the adrenaline rush going up those twisty bends then the horrified feeling i get when i find out i cant stop in time to make the turn without going into the incoming lane.
Hahaha. I'll try and hook you up with a cattle prod for the day. You supply the broom handle and a passenger to lean out the window and poke them - and we can all reap the benefits.
warmer?
i hope its nice and warm during the meet up
then during the cruise i hope it gets REALLLY REALLLY COLD.....nice air intake + most bike riders hopefully eff off.
then when we get to thornleigh i hope it hits 30 deg.
very unlikely. but who are you's to stop me from dreaming?
..what?
Ryan, don't worry about Albert's take on English.
If you really want to know, this is how the conversation is flowing:
Doof: "I never like Albert's events. But I'll most likely be making an appearance. First, though, I must check my schedule and make sure I don't already have plans for that day."
ShengBert: "What do you mean, other plans? THESE should be your only plans! If they're not your only plans, then cancel or reschedule what you had planned for that day, and come along to this event, or else..." :P:)
Lol Nick that made me laugh :P
I'd love to say I'll come but who knows when my new car will finally be ready..
Also, just a suggestion Albert but the cruise through Galston to Arcadia then through to Berowra Waters, over by ferry and then up the other side to Berowra Heights is quite a good one. Then just cruise up the freeway back to Hills area.
..what?
ehhh
what
Spot on!
You can make a good interpreter Nick!
:D
Lol Nick that made me laugh :)
Zilch!
Yeah your car will be ready =)
mm that sounds great, it that a far drive ?
Thanks, Nick. It's amazing how much info you can get out of just a few of Albert's words. :D
I like that Berowra suggestion - sounds good. It's a bit more of a drive than last time, but it'd be a nice change. Good point about being unfriendly to lowered cars, though. Would need to check on that.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
