NEXT MEETUP!
When: 31st August Sunday
Time: 2pm (yes im lazy..)
Where: Rouse Hill Maccas! (behind the Fiddler)
Whats happening: Meet up at 2pm, leave around 3ish, then cruise to Galston Gorge, then back to Thornleigh for more Maccas perv..
You guys should know the drill, wellll.. my drill, so no emos, ugly cats, bollocks...
And babes are allowed :rofl:
So Whose In!
https://www.sau.com.au/forums/topic/229285-hills-area-meetup-3/
  • Replies 239
Posted Images
Im in.
this time ill seriously run over those cyclists.
Ryan knows im not lying.
i love the adrenaline rush going up those twisty bends then the horrified feeling i get when i find out i cant stop in time to make the turn without going into the incoming lane.
Hahaha. I'll try and hook you up with a cattle prod for the day. You supply the broom handle and a passenger to lean out the window and poke them - and we can all reap the benefits.
warmer?
i hope its nice and warm during the meet up
then during the cruise i hope it gets REALLLY REALLLY COLD.....nice air intake + most bike riders hopefully eff off.
then when we get to thornleigh i hope it hits 30 deg.
very unlikely. but who are you's to stop me from dreaming?
..what?
Ryan, don't worry about Albert's take on English.
If you really want to know, this is how the conversation is flowing:
Doof: "I never like Albert's events. But I'll most likely be making an appearance. First, though, I must check my schedule and make sure I don't already have plans for that day."
ShengBert: "What do you mean, other plans? THESE should be your only plans! If they're not your only plans, then cancel or reschedule what you had planned for that day, and come along to this event, or else..." :P:)
Lol Nick that made me laugh :P
I'd love to say I'll come but who knows when my new car will finally be ready..
Also, just a suggestion Albert but the cruise through Galston to Arcadia then through to Berowra Waters, over by ferry and then up the other side to Berowra Heights is quite a good one. Then just cruise up the freeway back to Hills area.
..what?
ehhh
what
Spot on!
You can make a good interpreter Nick!
:D
Lol Nick that made me laugh :)
Zilch!
Yeah your car will be ready =)
mm that sounds great, it that a far drive ?
Thanks, Nick. It's amazing how much info you can get out of just a few of Albert's words. :D
I like that Berowra suggestion - sounds good. It's a bit more of a drive than last time, but it'd be a nice change. Good point about being unfriendly to lowered cars, though. Would need to check on that.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
