Hey
Was giving my GTR a bit of a hard time yesterday and now there seems to be a slight issue with the gearbox/clutch engaging
I put the clutch into the floor and when I attempt to change gears it crunches, much like when the clutch isn't engaged
Clutch doesn't slip, not even on high RPM or launching but its starting to crunch 4th gear now even on low RPM levels
I thought it may be the slave or master cylinder leaking pressure and not providing enough clamping pressure on the pressure plate to clutch, causing it to crunch but my dad checked both and it seems neither is leaking
Fluid looks clean with no leaks, according to service records the fluid has been recently changed
Any other thoughts or ideas on what it could be causing the problem
Thanks
https://www.sau.com.au/forums/topic/229469-gtr-gearbox-crunch/
Okay, well I thought I had it all sorted but it has started happening again
I topped up the fluid as it was a little low, pumped the clutch with the lid off and then tried again and it was fine for a few days, now its started doing it again on the odd occasion
Sometimes its fine then on randomly it will crunch into 4th for no reason
Does anyone know what the fk is up with it??
I'm going to drain the clutch fluid and put new fluid in it next week, then bleed the clutch. Hopefully that does it but some how I don't think its that as the clutch seems to work fine, no slip or anything and grips in every other gear
Thanks
It wont. If it was the clutch it would crunch all gears. No?
Dude its 4th synchro, theyre dynamite for crunching. Redline doesnt help either. Its not as miraculous as most say...
Might as well start looking for a new box lol, thats what I did! Fixed it real good.
It's happened in the past and it's been the clutch, in a previous car I had it was doing exactly the same thing but it was the pressure plate failing due to being weak causing the clutch not to engage 100% therefor making it hard to put it into gear
Also on the forums the cheap clutches that SLIDE was selling, EXEDY clutch plate and OEM pressure plate eventually started to do the same thing
Thanks
I have a GTS4 with a fairly badly crunching 4th.
Why not just try slowing down the speed of gear change?
Double clutch/heel-and-toe gears down.
5th -> Neutral -> 4th
Blipping throttle helps too
Yeah that's what I do to avoid it crunching but I'd rather not do that forever
I found with mine that double clutching did nothing - I noticed however that clutching, bringing the gearstick back slightly and allowing the revs to drop before putting it into 4th makes it smooth again 99% of the time - does not work for downshifts though so I just go straight to third, I'll try some Redline Shockproof Lightweight until ! can get the money together to try and get another GTR/Stagea box!
  • 3 weeks later...
Hey I know this is off the topic a little. My car use to crunch first at the lights and if you where a little miss timed with the clutch on the gaer change it would crunch. I got my clutch changed because all of a sudden I had a large vibration. I had cracked my flywheel. After replacing it I never crunched again. I think I am lucky my flywheel didn't let go when it finally decided to go. The only thing holding it together was the ring gear. So now I am alway carful when my car starts to crunch.
my 4th gear synchro's have been bad since the day i bought the car. as most are saying, its a very common problem in the GTR's. ive been "double clutching" the whole time. it helps it to the point where its virtually un-noticable. and if you get it right you can change almost as fast as you normally would. you just need to make sure that you match the revs.
